Recommended Parts
9 replies to this topic
#1 WillCarter
WillCarter
  • 523 posts
Posted 11 August 2018 - 01:08 PM
Sorry for posting a load of topics recently but I'm about to have another big order of parts.
What would you recommend for each of these? The build is a turbo 1293. So far I've got an HIF44, A+ block, cylinder head off of Phil (eventually), pistons, rods and a GT1752 turbo.
I'm looking at around 120bhp and probably a max of 10psi.
Thank you in advance and thank you everyone that has helped and has been a part of the build so far, I really appreciate it!
Crankshaft
Camshaft
Inlet Manifold
Outlet Manifold
Intercooler
Oil Cooler
Lightened Flywheel
X pin diff
Clutch
Head studs
Cam followers
Push rods
Big end bearing bolts
Rockers
Water pump
Fuel pump
Oil pump
Gaskets
Cam chain
Rocker cover
Intercooler piping
Air filter
Pumps
I've got around £2k to play with
Edited by WillCarter, 11 August 2018 - 01:09 PM.
#2 hazpalmer14
hazpalmer14
  • 682 posts
  • Local Club: cumbria mini cruisers
Posted 11 August 2018 - 09:08 PM
Standard crankshaft is fine. Metro turbo 6851 or what ever it is the better one would be good but not necessary.
Cam the phase 2 is a good bet. But any milder cam ideal. MG metro, Kent 500 (similar to mg metro), sw5 or a 266
Inlet manifold any after market alloy one is fine, but check it clears the manifold you are going to use as some clash! I'm using a metro turbo one and fusion fabs manifold.
Fuel pump I've just bought a Bosch copy of the metro turbo one from turbo Phil. Any high pressure fuel pump will do. If going into a round nose look for an mpi tank or spi (these limit the amount of boost you can run to 15psi IIRC but can be upgraded easily)
Intercooler get the biggest one you can fit. People use all sorts from various cars.
Oil pump you'll need an upgraded one there is a turbo pump. Look on turbominis prom because there was a bad batch going around so be careful. I did think this was resolved though.
Head studs, I've got the minispares 11 stud kit. 9 will do the job. Some people for the ARP head bolts.
Water pump get a high capacity one.
A duplex timing chain will do. You can get belt drives etc but not really needed.
Intercooler piping you can buy when you know what intercooler you have and where you are going to mount it. Most are made up of alloy bends and silicone hose.
Minispares x pin diff Ian up to the job. Don't think anyone has had Ann issue with them.
Standard rockers are all you need.
Standard push rods are fine.
Cam fillers if you get a cam kit it will have new followers in it.
Clutch/flywheel depends on if you want verto or pre verto. I use a minispares lightened verto. MED do nice ones to. And I use a RTS made using a 1275 and 998 spring I think. I bought it from john and andys metro van. You can get updated plates for these from minispares. A search on turbominis will bring up what people use. All been discussed before.
But genuine bearings and gaskets I'd suggest. I know some gaskets have different thicknesses depending on where they come from. So be aware when building your engine and checking clearances.
Air filter I bought a generic cone filter from eBay but am going to get a K&N or similar this time
Oil cooler may not be needed. Fit an oil temp gauge to see if you need one first. And if you do fit a thermostat to otherwise you will be cooling the oil from when you start the engine
#3 WillCarter
WillCarter
  • 523 posts
Posted 11 August 2018 - 09:16 PM
Thanks again Haz, massive help!
#4 hazpalmer14
hazpalmer14
  • 682 posts
Posted 12 August 2018 - 07:40 AM
Outlet manifold mine is fusion fabs one, need to take a little piece out the subframe and i use an adjustable engine steady to.
Best thing to do is search loads on turbominis forum. It has a great search function and is a wealth of information on there.
#5 WillCarter
WillCarter
  • 523 posts
Posted 12 August 2018 - 07:42 AM
I'll get over there and have a browse, cheers again!
Is the engine steady on minispares?
#6 hazpalmer14
hazpalmer14
  • 682 posts
Posted 12 August 2018 - 07:48 AM
most places do them, again i got one from turbo phil. Force racing do them do. Saying that i did get one from ebay with orange poly bushes and it didnt go long enough!! This was on a 1098 that need the extra clearance for a HIF carb. Later cars had longer ones so the bottom of the carb would clear the bulkhead.
#7 WillCarter
WillCarter
  • 523 posts
Posted 12 August 2018 - 02:42 PM
I'll have a look into that, cheers! I've just bought an sw5 cam so I'm after some rockers now. Also let me know if you're selling any spares that you think I might need.
#8 Turbo Phil
Turbo Phil
  • 2,418 posts
Posted 12 August 2018 - 03:07 PM
A good cam though it is an SW5 wouldn't be my first choice for a turbo build.
Phil.
#9 WillCarter
WillCarter
  • 523 posts
Posted 12 August 2018 - 03:42 PM
Phil.
What would you go with Phil?
#10 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 07 September 2018 - 05:14 PM
Yeah I don't rate a sw5 cam for a boosted set up. K500 or MG metro cam for me. Saying that, I'm on the supercharged side.
