Static Timing
7 replies to this topic
#1 Andrew22-10
Andrew22-10
  • 30 posts
Posted 13 August 2018 - 10:22 AM
i recently bought an Aldon 45/59D yellow distributor with vac. when i first fitted it the car fired but was very rough and wouldn't run long enough to do anything.  after a few attempts at turning the dizzy it it stopped producing a spark. i checked the battery and it is fine as are all the connections.
Can someone please help with this as it is driving me mental.
P.S it has points and a condenser with a single wire going to the coil -ve.
Thank
#2 sledgehammer
sledgehammer
  • 3,060 posts
Posted 13 August 2018 - 10:46 AM
hi
are you running a ballast ?
is coil ok & voltage correct
have points closed up
is condenser ok - new ones are common for failing
check nylon washer is stopping points shorting to base plate & condenser clip is the right way around , & can move & short points
check for resistance when points open & closed circuit when closed
short coil -ve to earth (on -ve earth car) with dizzi wire removed - do you get spark ?
Edited by sledgehammer, 13 August 2018 - 10:48 AM.
#3 Andrew22-10
Andrew22-10
  • 30 posts
Posted 13 August 2018 - 12:19 PM
I have now got a spark, there was a broken wire going to the coil so there was no power getting to it
Thanks anyway
#4 Andrew22-10
Andrew22-10
  • 30 posts
Posted 13 August 2018 - 02:31 PM
I still cannot get the started, would someone be able to tell me how to static time it. It does sound like it wants to fire and it sometimes does but it is very rough and cuts out again, it is getting fuel because the plugs are wet.
#5 sledgehammer
sledgehammer
  • 3,060 posts
Posted 13 August 2018 - 03:01 PM
firing order 1 3 4 2  anti clockwise from 1 o'clock position
static timing for a rough startup 6 degrees before TDC
if the engine kicks back against the starter or spitting thru carb it is too advanced - so turn dizzi ANTI clockwise a bit
if thudding thru exhaust it will be too retarded , so turn dizzi  clockwise
charge battery up before trying
best of luck
edit all the above for a basic a series setup , high performance setup may require different settings
edit corrected clockwise / anticlockwise  :ohno:
Edited by sledgehammer, 13 August 2018 - 07:11 PM.
#6 Cooperman
  • 23,036 posts
Posted 13 August 2018 - 03:30 PM
Turn dizzy clockwise to increase advance, anti-clock to retard.
#7 sledgehammer
sledgehammer
  • 3,060 posts
Posted 13 August 2018 - 07:09 PM
Ive corrected it now -
rookie mistake - oops - suddenly my brain had the rotor arm going clockwise - don't know why  :shy:
Edited by sledgehammer, 13 August 2018 - 07:13 PM.
#8 carbon
carbon
  • 2,590 posts
Posted 13 August 2018 - 08:54 PM
Andrew,
With a points type distributor setting up the static timing is straightforward as long as you have the flywheel with 1/4 - 5 - 10 - 15 markings on the rim and the window with small removable cover plate in the 'wok' so you can see the flywheel rim position.
If you have this set-up then using a small 12v lamp between coil -ve and the distributor wire allows you to see exactly when the points are opening and set the static timing.
