Fill the tank, then drive 150 miles and you should be safe to do it.
A mini should easily manage over 150 miles before running out, but take a jerry can if you are that worried.
Sports Pack Something Funny Going On With Fuel Gauge!
leepol83
, Aug 17 2018 09:15 PM
20 replies to this topic
#16
Posted 19 August 2018 - 05:46 PM
#17
#18
Posted 19 August 2018 - 06:00 PM
Great stuff no need to take out the tank then really thanks for that I’ll try the knife truck assuming u just tap it round ?
#19
Posted 19 August 2018 - 07:06 PM
If you locate the knife on the two lugs, you can use it as a lever to rotate the locking collar.
Tapping it round with something is the other way to do it, but I found my knife trick easier.
#20
Posted 19 August 2018 - 07:46 PM
Thank U lol update once I’ve done it
#21
Posted 19 August 2018 - 08:12 PM
I replaced my fuel sender unit a few weeks ago. I just siphoned all the fuel out into a couple of Jerry cans, replaced the unit and put the fuel back. If you are getting a new unit it might be worth replacing the gasket at the same time.
