what type is a normal HIF44 carb engine?
probably get mocked for this, but ive never had to chose parts wise before.
can someone tell me the diference? if a normal single carb a single point injection?
Posted 19 August 2018 - 09:45 PM
Posted 19 August 2018 - 09:46 PM
a carb is a carb Single Point Injection and Multi Point Injection are not.
Posted 19 August 2018 - 10:38 PM
Hi,
A carb is similar to SPI in that the fuel is sprayed onto the butterfly but that's the only similarity...
Posted 20 August 2018 - 06:31 AM
so when im looking at hose kits - there are mpi, spi and 998-1100 kist available, nothing for 1275s?
Posted 20 August 2018 - 06:45 AM
You'd want a "1275 pre-1989" kit like this
http://www.minispare...s/C-GRH002.aspx
http://www.minispare...RH002BLACK.aspx
http://www.minispare...-GRH002RED.aspx
Posted 20 August 2018 - 06:50 AM
Being an old wrinkly I get then same, don't know the names of these new fangled parts most of the time
HIF carb is from a larger engine than 1275 originally probably a maxi 1500/1750cc.
Minis use them they took the part of twin carbs just a bit better no need for tuning up every couple of months
hose kits most all fit the same 998/1100 will do yah
Posted 20 August 2018 - 07:18 AM
the only difference between the 998/1098 to the "standard" 1275 ín the water hoses is the rad top hose.
Edited by nicklouse, 20 August 2018 - 07:19 AM.
Posted 20 August 2018 - 11:04 AM
Clubman top hoses are a bit longer as well
Posted 20 August 2018 - 01:02 PM
Posted 20 August 2018 - 02:33 PM
ill be honest guys, im after some snazzy blue ones for the radiator
Posted 20 August 2018 - 09:27 PM
Then you want this one I linked aboveill be honest guys, im after some snazzy blue ones for the radiator
