Special Tools
62 replies to this topic
#1 JonnyAlpha
JonnyAlpha
  • 2,744 posts
  • Local Club: Exmoor Minis
Posted 20 August 2018 - 02:44 PM
Need to split a couple of engines as well as a drum to disc brake conversion. For the engine I think I'll need a flywheel puller - any particular type / supplier?
This one? or this one?
I will also be doing a drum to disc conversion using the fund made from breaking these Metros so what about a ball joint splitter?
Any recommendations would be great.
#2 hazpalmer14
hazpalmer14
  • 682 posts
  • Local Club: cumbria mini cruisers
Posted 20 August 2018 - 02:55 PM
scissor type ball joint splitter is better then the fork type. I bought a fork type one being a cheap skate and it was useless took far longer to split joints then using the scissor type
#3 GraemeC
GraemeC
  • 7,315 posts
Posted 20 August 2018 - 03:19 PM
Ideally this one:
http://www.guess-wor...play.htm?id=501
But if it is too expensive and you can do all the engines at the same time then you could rent one from him
And this type of ball joint splitter:
Edited by GraemeC, 20 August 2018 - 03:20 PM.
#4 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,017 posts
Posted 20 August 2018 - 05:05 PM
I think I've got one of the laser ones, come from halfords. I'll have a look later for it, if you're interested in it, I ended up buying one of the guessworks one.
Edited by alex-95, 20 August 2018 - 07:43 PM.
#5 ukcooper
ukcooper
  • 1,625 posts
Posted 20 August 2018 - 06:24 PM
if ya in for the long run, quality , works well , well well made and I love mine works just ace http://www.guess-wor...play.htm?id=501
messed a few off the cheaper, ones and Guessworks never let me down  just recommended highly
#6 dotmatrix
dotmatrix
  • 390 posts
Posted 20 August 2018 - 06:50 PM
Do you still have the metros? Where are you Selling All non engine metro parts?
#7 nicklouse
  • 17,945 posts
Posted 20 August 2018 - 06:51 PM
those are the same, which ever you get lube the big bolt.
#8 wile e coyote
wile e coyote
  • 1,224 posts
Fork balljoint splitters get a bad rep as often they're the wrong size and badly made - I've got a really old williams superslim one - never fails and doesn't ever rip rubbers either, unless they're truly rotten in the first place - (nothing to do with me but one on fleabay at the moment https://www.ebay.co....97355181?chn=ps ) that said scissor types are good too ...
The laser flywheel puller is pretty good - but I along with probably plenty of others have busted the odd one....for a couple of uses it'd probably be ok so long as the flywheel is not a particular sod (they can be!)
Very few special tools needed for a mini thankfully - the only specific ones in my toolkit being cone and bendix gear compressors.
In general terms a selection of quality imperial spanners and sockets (in both 3/8 & 1/2") a bucket full of penetrating oil and a huge breaker bar will see you done easily........
A decent brake adjuster spanner worth every penny though.....
#9 JonnyAlpha
JonnyAlpha
  • 2,744 posts
Posted 20 August 2018 - 07:16 PM
I did list on Metro Power For Sale on Facebook last year when I first came across them but never got around to doing anything. Apart from removing one of the engines and the carbs, I haven't started on the rest. I am compiling a list of anyone that wants anything. PM me and let me know what you are after.
#10 nicklouse
  • 17,945 posts
Posted 20 August 2018 - 07:18 PM
for comparison
#11 JonnyAlpha
JonnyAlpha
  • 2,744 posts
Posted 20 August 2018 - 07:27 PM
What about an Engine Stand. Looks like a complete engine is 330lb so would this smaller Clarke one do. It is rated at 340KG.
Also need an A Series Adaptor. This one?
#12 JonnyAlpha
JonnyAlpha
  • 2,744 posts
Posted 20 August 2018 - 07:31 PM
for comparison
That's a beast, no wonder it's so much more expensive.
to be honest I need to split two engines to check them before I sell them on and I also need to check / change the clutch on mine. The two engines have been sat for a long time and will no doubt be stiff?
#13 Twincam
Twincam
  • 1,742 posts
  • Local Club: SMAG
Posted 20 August 2018 - 07:47 PM
If you do end up using a fork splitter, I've found coating the fork ends in grease before using. It slides over the boots so they don't split and haven't had an issue with them.
I've got the scissor type one that I use if I'm taking a bit more time on cars but if you're replacing the ball joints you don't have to worry.
#14 JonnyAlpha
JonnyAlpha
  • 2,744 posts
Posted 20 August 2018 - 07:50 PM
Just seen a brand new 450KG one for under £40 :-)
here
#15 JonnyAlpha
JonnyAlpha
  • 2,744 posts
Posted 20 August 2018 - 07:53 PM
Just bought the Williams Super Slim (had some PayPal Credit so what the heck.
