Remote Brake Servo On Dual Line Brakes
Posted 20 August 2018 - 08:10 PM
Do I put a single line master cylinder in, plumbed into the servo, then on to the bias valve on the bulkhead, to get better pressure to all of the brakes, or...
Stick with my existing master, fronts plumbed to the servo, and keep the backs as they are?
Thanks in advance.
Posted 20 August 2018 - 08:36 PM
Posted 20 August 2018 - 09:10 PM
I personally prefer no servo and single line, like me its simple
If you go single line, the servo can go next in line before the front / rear T
Has your 'bais valve' on the bulkhead got 4 pipes ?
If so its the FAMWTF valve on the bulk head and needs binning they are an unknown un-testable piece of crap...
Then you need a brake bias valve for the rear to replace the T you probably have on the rear subframe.
You can then use the standard brake bias valve mounted on the rear subframe, simples
I do a kit with the bias valve and two adaptors to replace the FAMWTF valve for twin master cylinders
Posted 20 August 2018 - 09:36 PM
Okay, will do, thanks.
Got a link to your kit?
Posted 21 August 2018 - 09:32 PM
Posted 21 August 2018 - 10:21 PM
Be aware that dual circuit brakes are a C&U requirement if your car is later than '76.
You can servo just the front circuit, Innocenti did.
Posted 20 September 2018 - 09:01 PM
