Morning all!
what reading should I be getting from a 1380 engine with standard rockers. it's had a recent rebuild and the previous owner drove it a few hundred miles and reported no problems. I stuck a tester on it and only managed around 50psi across the cylinders. test was on a cold engine (had only run for a couple of mins) all the plugs out and dry bores (no oil down them)
although the reading was low, it was even and the colour of the plugs was nice and brown. just puzzled by the really low reading. the engine had no numbers so dont know what it was in previously... could it have been a turbo engine with the turbo removed?? they are meant to run at a reduced PSI but surely not 100psi lower?
