Edited by GraemeC, 20 September 2018 - 07:49 PM.
Posted 01 September 2018 - 08:41 AM
Posted 06 September 2018 - 04:09 PM
Posted 06 September 2018 - 08:24 PM
Posted 06 September 2018 - 09:11 PM
No need to want...just buy!!
Posted 11 September 2018 - 12:03 PM
Posted 11 September 2018 - 01:53 PM
i suspect the jacking point isn't strong enough to support a fully loaded commercial. with saloons or estates most of the load would be the occupants, and you'd assume they'd be out of the car before it was jacked up.
Posted 14 September 2018 - 08:59 AM
Looking through the receipts, this has had a full M-machine floor assembly put into it.
There's been a lot of money and work put into this already - a proper blank canvas just prime for someone to finish off to their taste. And an easy project too.
Edited by GraemeC, 15 September 2018 - 03:10 PM.
Posted 23 September 2018 - 03:18 PM
Jacking point on these is the drain tube which goes through the load floor and is welded to the inner cill.i suspect the jacking point isn't strong enough to support a fully loaded commercial. with saloons or estates most of the load would be the occupants, and you'd assume they'd be out of the car before it was jacked up.
