Supercharged Classic . Hot Spot Once Turned Off ?
Posted 02 September 2018 - 07:23 AM
Posted 02 September 2018 - 04:44 PM
I've heard some Turbo'd cars need running on tickover for a while after use to allow heat to dissipate from the oil - not sure if S/c's have the same issue?
Posted 03 September 2018 - 11:41 AM
This is to allow oil to circulate around the turbocharger, as a sudden loss of oil whilst still hot would knacker the internals.
Posted 03 September 2018 - 11:43 AM
Hi , My Vmax Scart supercharged classic 1275 has an issue where although the oil temp and engine temp gauges show normal when running , on turning the engine off I get intermittent bubbling in the expansion tank after 20 seconds or so, The car has a high flow front mounted radiator, any ideas as to how I can stop this , Or is it not an issue !
Possibly air in the system. It may need bleeding to release the air.
Posted 03 September 2018 - 12:11 PM
Hi,
Test or replace the rad cap would be my first move ...
Posted 03 September 2018 - 04:32 PM
Posted 03 September 2018 - 09:24 PM
Posted 04 September 2018 - 09:10 AM
