Does the Solus have a selection for the Mini year you are scanning?
This thread has some good documentation in it:
http://www.theminifo...-perhaps/page-5
The RCL0193 manual supplement has information about the MPi and the AKM7169 has info on the SPi.
You may have to dig through it to find valid links though.
There is also an article on working with the MPi from one of the magazines.
Is there a particular issue you are trying to resolve?
Terry
EDIT:
Depending on the coolant temp sensor in use, a similar type was used on some of the MGF and a I believe a Caterham/Seven also used this sensor.
This site has some information:
http://www.tom-seven...perature_sensor
Somewhere in the site there are voltage values but not resistance values. I don't see them right off.
The values in the table never matched the values I got in my voltage testing.
Another edit:
This is the page from the German MGF site that has resistance values for the sensors. MGF actually uses two sensors for coolant, one for gauge and one for the ECU
https://www.mgfcar.de/sensor/
Edited by tmsmini, 17 September 2018 - 12:30 AM.
