Tie Rod Bolt Failure
Best Answer spraybeater , 15 September 2018 - 09:22 AM
Good idea to fit new one, including the proper bolt through the bottom suspension arm.
+ new nylocks! on both looks like thats been cross threaded and the threads stripped by some
ham-fisted moron.
Go to the full post#1
Posted 14 September 2018 - 10:19 PM
Posted 14 September 2018 - 10:23 PM
often when the wrong bolt is fitted.
Posted 14 September 2018 - 11:28 PM
Sorry . not quite with you on your explanation. You are talking tie rod not track rod? It failed catastophically as in arm broke or dropped out caused severe veer or other>? If you can see the thread in entirety has it just backed out of the front keeper or has the back bolt sheered. None of these are good and i am glad you pulled over successfully , but just trying to picture the scenario
Posted 14 September 2018 - 11:44 PM
how old is the part ?
was a pot hole involved ?
the problem is mini's are all getting old now & the corrosion / fracturing is hidden in that area
Posted 14 September 2018 - 11:59 PM
Since a bush is mentioned I'm assuming it's the subframe end of the tie rod. I've not heard of it happening but a lower grade nut and/or overtightening of the same might do it.
Posted 15 September 2018 - 12:15 AM
but there is only one bolt?
unless it is a rose jointed set up that has 2 bolts.
as said clarity is required.
Posted 15 September 2018 - 07:10 AM
Posted 15 September 2018 - 07:33 AM
Picture of car on recovery truck, this was the position of the rod post failure ,
IMG_3401.JPG 100.05K 63 downloads IMG_3401.JPG 100.05K 63 downloads
Posted 15 September 2018 - 07:44 AM
Posted 15 September 2018 - 08:02 AM
the only way the tie rod can come out like that is if the nut is missing from the end - it either wasn't fitted, or has come off (..takes a long time for a nut to 'walk off' by itself so i wouldn't expect the threads to be clean)
i'd be looking to see what type of nut has been used to secure the other tie rod - locknuts should be in use i believe
Posted 15 September 2018 - 08:40 AM
I will replace the whole lot just so I know the nuts and bushes are of good quality , Currently all rubber bushes, The lug can be seen in the picture just beside the end of the rod, the towing eye is a good bit higher and nothing to do with the issue.
Posted 15 September 2018 - 08:47 AM
Posted 15 September 2018 - 09:22 AM Best Answer
ham-fisted moron.
Posted 15 September 2018 - 09:52 AM
Needs to be special long shanked bolt and preferably nyloc nut. Fully threaded bolts are weaker.but there is only one bolt?
Edited by whistler, 15 September 2018 - 09:52 AM.
Posted 15 September 2018 - 09:58 AM
Another couple of thoughts.....
Incorrect thread type
Could it have been tampered with, upset any neighbours?
