Bottom Pulley Removal
engine
19 replies to this topic
#1 Hugh Jass
Hugh Jass
  • 64 posts
Posted 20 September 2018 - 08:23 AM
Hi,
I bought my little 1989 Mini City E to renovate.
Any advice on getting a bottom pulley off?
My method of choice will be a socket, with a bar, with a scaffold pole and an 18-stone weight swinging off the end.
Do most people use the gearbox to stop the engine turning?
Should I just borrow a compressor and air gun?
Any advice gratefully received.
#2 Dusky
Dusky
  • 5,322 posts
Posted 20 September 2018 - 10:19 AM
Lock the flywheel ?
#3 JCmini
JCmini
  • 146 posts
Posted 20 September 2018 - 10:24 AM
Try just using a socket on it and holding the pulley with the other hand. I don't think there that hard to take off.
#4 nicklouse
  • 17,944 posts
Posted 20 September 2018 - 10:35 AM
some sockets will not fit with the bracket in the way. so you will need a spanner or bracket off.
and lock the flywheel.
#5 DeadSquare
DeadSquare
  • 2,767 posts
Posted 20 September 2018 - 10:36 AM
You shouldn't need a compressor and an air gun, or a 20' scaffold pole, a bar and 18-st should be ample with something wedged in the starter ring rather than putting the car in gear.
I'd remove as much as you can of the mucky dirt first, as you don't want it going into the hole when the pulley comes out.
By the way, why are you removing the pulley?
#6 Hugh Jass
Hugh Jass
  • 64 posts
Posted 20 September 2018 - 10:56 AM
I want to check the chain and tensioner etc (standby for pictures and questions on here :lol: )
The car hasn't run since 1995. Somebody else completed all the welding on the car but I am just stripping down to check everything before I try and start it.
#7 Hugh Jass
Hugh Jass
  • 64 posts
Posted 20 September 2018 - 10:57 AM
Thanks for the advice by the way. I''l take the starter off and have a look.
#8 nicklouse
  • 17,944 posts
Posted 20 September 2018 - 10:58 AM
does it sound rattley? if not don't bother looking.
#9 DeadSquare
DeadSquare
  • 2,767 posts
Posted 20 September 2018 - 11:26 AM
Hmmm.  I'd be inclined to leave well alone, on the principal that "If it ain't bust, don't fix it"
#10 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 20 September 2018 - 12:41 PM
If you are going to the hassle of checking it you may as well renew the chain and tensioner.
Make sure you use a good quality chain, IWIS.
A 1/2 drive rattle gun is the quick way to remove the bolt but difficult in car [ you don't need to lock the flywheel then either ]
Don't forget there is a lock tab too
#11 DeadSquare
DeadSquare
  • 2,767 posts
Posted 20 September 2018 - 01:35 PM
Darn it, the ruddy thing only ran for 6 years.
It's hardly run-in.
#12 Hugh Jass
Hugh Jass
  • 64 posts
Posted 20 September 2018 - 03:39 PM
If my lady wife keeps messing about in the garage near where I carefully arranged my push rods it might need running in again.
#13 DeadSquare
DeadSquare
  • 2,767 posts
Posted 20 September 2018 - 04:22 PM
If the push rods are clean and grease free, draw rings up the stem from 1 to 8 with a marker pen, starting at the water pump end.
If they are a bit oily, put a flap of masking or sellotape round them with the number.;  ditto the cam followers.
Number the valves in the same way.
Dot, with a punch the con rods and their caps 1-4 from the water pump end and mark the center main bearing cap and the block beside each other so that goes back on the same way.
This all helps someone else rebuild the engine when your wife bans you from the garage.
#14 mk1leg
mk1leg
  • 9,341 posts
Posted 20 September 2018 - 08:12 PM
did you unlock the bolt first
#15 Cooperman
  • 23,039 posts
Posted 20 September 2018 - 08:45 PM
Lock the crankshaft by removing the starter motor. Lock it at TDC with No.1 cylinder firing as that makes changing the chain easier as the 'dots' on the sprockets will be in line without turning crank or cam further. Don't move the crank or cam when removing or re-fitting the sprockets.
