Wrong V Belt Fitted To My Car.
Posted 23 September 2018 - 11:00 AM
Just gone to change the V belt on my 97 Cooper mpi.
The old belt was a Dayco 5pk935 - the new one is a 5pk925.
Everything online says its the 925, but it’s shorter and won’t fit.
The 935 fits perfectly, but according to part shops online, the 935 doesn’t fit Mini’s at all.
Anyone else had this issue?
What would cause this change?
Many thanks
Posted 23 September 2018 - 12:10 PM
Maybe a larger diameter water pump pulley has been fitted.
Have you tried removing the adjuster bracket completely, might give a bit more room to get the new belt on.
Edited by panky, 23 September 2018 - 12:13 PM.
Posted 23 September 2018 - 12:17 PM
Hi,
MPI belts are difficult to get on, maybe someone fitted the longer one for that reason.
I undid the adjuster bolt all the way then slackened the pulley clamping bolt off so it was only just hanging on then fit the belt.
Posted 23 September 2018 - 01:15 PM
Posted 23 September 2018 - 01:24 PM
Edited by Wiggy, 23 September 2018 - 01:25 PM.
Posted 23 September 2018 - 06:46 PM
Posted 23 September 2018 - 09:34 PM
Hi guys, thanks for all the comments.
I will have another look, but the 935 is really tight and seems to fit perfect. Im happy to leave it on, but just wanted to know why it was on there in the first place.
I was only replacing it as i didn't trust the previous owner, so i have been replacing all the service items like this so that i know they are good.
Has anyone got a user guide / instructions (other then Haynes) just encase i have missed anything.
Posted 23 September 2018 - 10:16 PM
Haynes is as good as anything regarding basic servicing.
Posted 24 September 2018 - 04:22 AM
Posted 24 September 2018 - 04:54 AM
The only difference between the two is 10mm, or about 1% difference in overall length. It might have been the only belt in stock at the time when the previous owner changed it, or perhaps it was recommended to them as it's easier to fit.
Posted 25 September 2018 - 07:59 PM
As for instructions, I was thinking something a bit more detailed then Haynes with photos.
Posted 25 September 2018 - 08:16 PM
