Mpi Coolant Type And Hoses
15 replies to this topic
#1 SE10 Mini
SE10 Mini
  • 37 posts
Posted 24 September 2018 - 04:42 PM
Happy Monday Forum Guru's.
The below photos of my 2000 Mini Mpi Cooper Sport are in hope of someone confirming the type of coolant that I need!
Am I right in saying that this is the OAT Type?
If so does what type and where from? pre mixed or concentrate? where is the ratio listed?
All the above is because my car has been running really hot recently, but not really showing hot on any gauges. engine bay temp has been crazy warm after trips, so just wanted to do the basics first. Drain, flush, new coolant, new expansion tank cap and maybe new hoses (probably more cosmetic than an actual requirement!)
Someone said that it might be a head gasket, someone else said it might be the thermostat, but I wont be able to do those jobs on my own due to lack of skills! but am happy to have some feedback.
So, thoughts please, happy to listen to all advice.
Ed
#2 nicklouse
  • 17,945 posts
Posted 24 September 2018 - 05:57 PM
is the fan coming on?
Attached File  Capture.JPG   73.85K   1 downloads
#3 the.stroker
the.stroker
    TMF Admin
  • 4,348 posts
  • Name: Dan
Posted 24 September 2018 - 06:07 PM
http://www.theminifo...ze#entry2589432
Loads of info about this, carry out a quick search, should give you enough bedtime reading.
#4 Steve220
Steve220
  • 4,896 posts
  • Local Club: BMC
Posted 24 September 2018 - 08:38 PM
Comma G48 is ideal.
#5 Bobbins
Bobbins
  • 1,345 posts
Posted 29 September 2018 - 05:33 AM
Comma G48 is ideal.
Diluted or as it comes?
#6 Steve220
Steve220
  • 4,896 posts
  • Local Club: BMC
Posted 29 September 2018 - 01:41 PM
Diluted, it's a concentrate.
#7 Bobbins
Bobbins
  • 1,345 posts
Posted 29 September 2018 - 08:40 PM
Cheers :)
#8 Kubbar
Kubbar
  • Just Joined
  • 82 posts
Posted 04 October 2018 - 08:23 AM
Go with evans power coolant
#9 nicklouse
  • 17,945 posts
Posted 04 October 2018 - 12:14 PM
why would anyone you that crud in a Mini?
#10 RooBoonix
RooBoonix
  • 1,224 posts
Posted 04 October 2018 - 03:57 PM
Agreed, I don't like the stuff. It's expensive, finds every leak possible and is just a pain in general
#11 nicklouse
  • 17,945 posts
Posted 04 October 2018 - 08:50 PM
and as it is mainly Glycol transfers heat worse than a 50% mix of water and antifreeze.
#12 RooBoonix
RooBoonix
  • 1,224 posts
Posted 05 October 2018 - 05:40 AM
But Ed China is on the bottle it must be good!!!!
#13 SE10 Mini
SE10 Mini
  • 37 posts
Posted 05 October 2018 - 10:46 AM
I am sorry, but I am confused.
My coolant is the Red OAT Type.................but people seem to be saying that I should change it to the green/blue type?
HELP ME PLEASE
#14 Kubbar
Kubbar
  • Just Joined
  • 82 posts
Posted 05 October 2018 - 12:53 PM
I live in Kuwait country you can google it and see our weather which the temperature is very severe ranging from 45 to 50 degrees Celsius and do not bear the engines so that the temperature is higher than usual as you have a nice weather and cool so I have experience in the acquisition of water Radiator fit for all seasons and gives good results. if your car from Type Mini Classic carburetor ans SPI Preferably to be green coolant. And MPI cars to use red or orange or pink coolant I have used Evans after gave me the best results there is no pressure of air and there is no seed water and did not raise the temperature of the car quickly.
It is true that it is expensive but in return you will feel comfortable and calm and you drive the car.
I did a search for the Coolants
It turns out that the green for classic cars that have a brass radiator
The red is now used for all cars and is suitable for the aluminum radiator and gives long distances to be replaced
See the attachment
Regards
Edited by Kubbar, 12 October 2018 - 09:56 AM.
#15 RooBoonix
RooBoonix
  • 1,224 posts
Posted 05 October 2018 - 02:23 PM
HELP ME PLEASE
Stick with your OAT coolant as previously suggested.
Switching to another coolant, like Evans waterless, isn't easy as you need to fully flush the system and make sure no water is left (easier said than done!). If you're not having issues with your current type of coolant, then don't bother changing.
