Nvq2 Practice - Evil Cambelt
10 replies to this topic
#1 Miss.S.L.Hope
Miss.S.L.Hope
  • 23 posts
Posted 25 September 2018 - 08:25 PM
Documentation / Notes for my NVQ2 Engine Section
Currently I only have one part left within my Engine section of my NVQ2 which is the Cambelt section .. Ergh.
Previous Experience with this would be over 2 years ago I assisted a work colleague with 2 Cambelts at work so he could attempt to teach me. I have since forgotten most of what he taught me that day and my current garage are not running my apprenticeship therefore its a case of trial and error at home.
VW Golf Mk4 - Cambelt Practice Attempt One..
Luckily my front garden looks like a scrap yard and we have a VW Golf Mk4 that requires a Head gasket replaced so my amazing partner has allowed me to practice my Cambelt on this one first (As if I screw this one up the engine technically it was already broken..)
Edited by yeti21586, 06 July 2019 - 07:34 AM.
DO NOT TRY AND AVOID THE SWEAR FILTER!!!
#2 Twincam
Twincam
  • 1,742 posts
  • Local Club: SMAG
Posted 25 September 2018 - 08:49 PM
Once you've locked everything in place, it shouldn't be hard to do them.
Is the Mk4 transverse or longitudinal? The MK2s I used to do with just tippex on the sprocket/pulley and away I went but there should be timing tools which allow for no margin of error.
#3 Miss.S.L.Hope
Miss.S.L.Hope
  • 23 posts
Posted 25 September 2018 - 08:58 PM
So, I've just discovered you can no longer add photos on here which ruins my plans of a detailed write up. Afraid it will be a old fashioned step by step guide.
The theory is there in my head as I've done a lot of research before I started, however I need to be able to do it start to finish with confidence otherwise my NVQ man will never sign it off. Its Transverse, I haven't added it yet but I've got that far but want to practice with timing pins as well as the car I get at college may need to be done with Pins rather than timing marks as I have no idea what I'll be working on until I turn up. :)
#4 GraemeC
GraemeC
  • 7,473 posts
Posted 25 September 2018 - 09:07 PM
You can add photos using imgur
#5 Allrounder
Allrounder
  • 188 posts
  • Local Club: Hereford Motor Club
Posted 26 September 2018 - 06:49 AM
Does you current workshop use a tech site like autodata! Step by step instructions on them to take the guesswork out. If not then a timing belt kit from gates usually has them in.
#6 Wiggy
Wiggy
  • 1,037 posts
Posted 27 September 2018 - 03:51 PM
I've done a MK4 Golf 1.6 16V. I used 2x 8mm? drill bits as locking tools for the cams. I was surprised at how easy it was.
#7 Miss.S.L.Hope
Miss.S.L.Hope
  • 23 posts
Posted 08 October 2018 - 04:58 PM
I couldn't work out the Imgur, So i'll go back to it.
Luckily I've got a Timing Belt book plus I printed off the Autodata version as well.
I also have a box with a assortment of Timing Pins so one should fit.
I'm still in the process of practising as it keeps Raining. I hate Rain :(
#8 minimat
minimat
  • 690 posts
  • Local Club: anglian mini club
Posted 10 October 2018 - 10:34 AM
Piston no1 at tdc (nearest belt end) line up crank pully mark or make your own using tippex loosen tensioner and remove belt , replace tensioner and belt along with the water pump and refit new belt, crank engine over twice to make sure the marks still line up, i refit a road wheel and put it on top gear, if all good refit covers and aux belt etc, job done
#9 Wiggy
Wiggy
  • 1,037 posts
Posted 11 October 2018 - 04:50 PM
I bought said Golf cheaply from a 'VW Specialist' off of eBay, for a mate. It ran but kept giving a MAP sensor error.
When I checked the (brand new) Cam belt, I found they'd timed it with a casting mark instead of the timing mark.
Just something to be aware of.
#10 Miss.S.L.Hope
Miss.S.L.Hope
  • 23 posts
Posted 24 April 2019 - 10:36 PM
I'll be adding this one onto my webpage in about 2 weeks. :)
https://thelittledoris.wordpress.com/
Ta Muchly :)
#11 Miss.S.L.Hope
Miss.S.L.Hope
  • 23 posts
Posted 05 July 2019 - 09:57 PM
Howdy,
For those who might be interested; My template website has now moved onto its live site & therefore has a new web address ‍:)
www.TheLittleDoris.co.uk
Unfortunately all my content is running off one website at the moment, and it’s full of my The Little Doris work rather than mechanical content :(
I’ll pop back & let you know when the mechanical content is uploaded :). In the meantime my profile will be dormant until I get a Mini of my own (Fingers crossed.. One day.. )
Thank you all for being so lovely while I’ve been here & good luck with all your Mini projects.
Ta Muchly, S Hope ‍:)
