Turbo Mayfair Sleeper
105 replies to this topic
#31 Bat
Bat
  • 903 posts
Posted 04 October 2018 - 09:41 AM
Hi,
It's probably no words or better than anything else these days.
All you can do is look to see if it's good quality alloy and good welding then bolt it on!
Cheers  :proud:
Edited by Bat, 04 October 2018 - 09:42 AM.
#32 GreaseMonkey
GreaseMonkey
    Has Ratchet, Will Make Noises
  • 3,663 posts
Posted 04 October 2018 - 10:25 AM
That is an incredible looking manifold!
#33 jsyjamie
jsyjamie
  • 76 posts
Posted 05 October 2018 - 08:21 AM
Engine - Intercooler
The bigger the better? Nope as this can create lag.
What can you actually fit under a round nose without it hanging out the front like some 90’s Max Power Mag wannabe…no offence.  ;D
I took a few measurements and luckily having an MPi engine with no dizzy, higher alternator mount and moving the front radiator to the side meant there was definitely enough room.
Ebay has loads of universal intercoolers and I went for a conservative core size. It was only £60 delivered so if (when) I need to upgrade it at a later date it won't be an issue.
Core size: 136mm x 330mm x 65mm
Inlet & outlet size: 56 x 56mm
Attached File  36832225_10160692489755472_3957442519335174144_n.jpg   50.72K   3 downloads
Some mounting fabrication will be required and I now need to work out where the pipe work will go...
Cheers,
Jamie
#34 Steve220
Steve220
  • 5,142 posts
  • Local Club: BMC
Posted 05 October 2018 - 12:37 PM
You'd find very little difference in lag with the core size. It's the boost piping that has more of an impact, but again, doesn't have that much of an impact.
#35 jsyjamie
jsyjamie
  • 76 posts
Posted 05 October 2018 - 12:56 PM
Suppose when we're only looking at small ish horse power compared to Jap engines.
Which piping and connections did you use Steve?
#36 Steve220
Steve220
  • 5,142 posts
  • Local Club: BMC
Posted 05 October 2018 - 01:20 PM
I've had all mine custom made by Fusion Fabrications. The silicone joiners are from Viper performance as their factory isn't that far away.
#37 jsyjamie
jsyjamie
  • 76 posts
Posted 05 October 2018 - 02:04 PM
I've seen the name before, I'll have a look at their website, thanks!
Also which cam did you go for in the end as I can't remember seeing it in your thread?
I would like to use the Phase 2 but not sure it would work in the MPi engine...
#38 mini13
mini13
  • 3,811 posts
Posted 05 October 2018 - 06:17 PM
Use the 274i cam, it's for mpis and has the cam sensor lobe, and is also well suited for forced induction, not quite as hot as a phase 2 but getting there.
#39 Steve220
Steve220
  • 5,142 posts
  • Local Club: BMC
Posted 05 October 2018 - 08:21 PM
If he's using the SC kit, you don't need the cam sensor lobe.
#40 mattmiglia
mattmiglia
  • 515 posts
Posted 05 October 2018 - 11:40 PM
There’s a thread on turbominis about those Chinese rads, seems quite good results overall with them
#41 Chris.Williams
Chris.Williams
  • 679 posts
Posted 06 October 2018 - 06:53 PM
Engine – Manifold
Memories of friends modifying their bulkheads to fit a turbo made me shudder but using the GT1752 and a new manifold meant that this wasn’t required.
Fusion Fabrications was the name which kept popping up and the quality of the products on their website and Facebook page looked incredible.
https://www.fusionfa...nd-downpipe-kit
Browsing on the Facebook page the side mount manifold and downpipe came up and looked amazing. I reached out to Matt and placed an order. In for a penny, in for a pound, may as well do this properly!
A few weeks later another expensive box turned up on my door step. Pure weld porn!
Fit's like a glove.
Cheers,
Jamie
A thing of pure beauty!
#42 jsyjamie
jsyjamie
  • 76 posts
Posted 08 October 2018 - 07:57 AM
Gearbox – Gear Set
One of the weak points in pursuit of big power from the A Series is the gearbox.
I remember friends having the Clubman straight cut gear set in their 1380s back in the day and you could hear the whine coming a mile away! As I wanted this to be a daily and would be driving several hours to and from tracks in Northern France the noise was going to be too much.
On the Mini Spares website, I saw the other (typically more expensive) option was their Helical heavy-duty kit. Stronger, quieter, almost the same ratio as the Clubman set and according to their website “Tested by Bill Richards for 400 laps at Brands in his 160HP 8 port engine under race conditions with our twin pin diff”.
http://www.minispare...ic/C-STN48.aspx
My aim is 160-180bhp so this sounded ideal!
Attached File  IMG_7648.jpg   62.81K   0 downloads
I also ordered the famous Mini Spares cross pin diff at the same time.
Attached File  IMG_7646.jpg   35.96K   0 downloads
Attached File  IMG_7647.jpg   36.22K   1 downloads
Not sure how bad the torque steer will be, hopefully I won't need to change it for an LSD...
Cheers,
Jamie
#43 jsyjamie
jsyjamie
  • 76 posts
Posted 12 October 2018 - 07:44 AM
Engine – Pistons
To lower the compression ratio we need some dished pistons and head work.
There is a great thread on TMF where people post their engine specs and what bhp they have achieved. Some of it can be taken with a pinch of salt as different rollers show different levels of power etc. but it is an excellent reference point.
http://www.turbomini...tid=521210&fr=0
+20 1293 looked the way to go as if anything happened to the engine it could be rebored.
The question is whether to go for the 10cc Cast or the 18cc Forged Omegas…
http://www.med-engin...ed-pistons-18cc
http://www.med-engin...ast-pistons-020
There is a fair price difference and by the looks of it some people are running the cast pistons up to 20psi and 200bhp. Is it a case of that’ll do or go big or go home?
Here’s your answer…
Attached File  IMG_7673.JPG   53.17K   0 downloads
Attached File  IMG_7674.JPG   45.73K   1 downloads
Attached File  IMG_7675.JPG   46.19K   0 downloads
I’m not going mental as I would like to keep it as a daily, so cast are good enough for me.
I am aiming for a compression ratio around 8.50 so with the 10cc dish and using this calculator the cylinder head volume needs to be 27cc.
https://jscalc.io/ca...RNEglVkKLQir11T
Cheers,
Jamie
#44 jsyjamie
jsyjamie
  • 76 posts
Posted 03 January 2019 - 04:17 PM
Quick Update
Apologies for the lack of updates but child one was born recently and not surprisingly my free time has diminished significantly!
So just a quick one for now of some other bits I've bought recently and I'll do a proper post over the weekend.
Cam Choice - Avonbar Phase 2
After doing some research and checking if it would work on an mpi engine with the SC kit I went for the Phase 2. It seems to be pretty much standard in all turbo engines looking to make decent power and has a good linear power delivery.
http://www.avonbar-r...urbo-cam-Billet
Attached File  IMG_7676.JPG   40.44K   2 downloads
MED Steel-Alloy Vernier Duplex
https://www.med-engi...-vernier-duplex
Attached File  IMG_7672.JPG   54.6K   0 downloads
KAD
Brakes had to be KAD especially when the red is a similar colour to the car. I plan on running 12 x 5.5 Super/Ultralites to keep the sleeper/OEM look so went for vented 8.4" disks.
https://kentautodeve...ant=55078756231
Attached File  IMG_7732.JPG   45.43K   0 downloads
Attached File  IMG_7731.JPG   46.66K   2 downloads
I also ordered their quick shifter and adjustable gearbox steady kit which would definitely be needed as the LH engine steady needs to be removed to accommodate the side mount turbo.
https://kentautodeve...nge-quick-shift
https://kentautodeve...rbox-steady-kit
Attached File  IMG_7733.JPG   34.15K   0 downloads
Cheers,
Jamie
#45 Dannyboolahlah
Dannyboolahlah
  • 168 posts
Posted 03 January 2019 - 09:53 PM
This is going to be awesome. That side mount manifold makes me weak at the knees!
