Turbo Mayfair Sleeper
#61
Posted 05 March 2019 - 09:31 AM
I’m currently doing a very similar build (I have also been deciding on pistons for months)
I am currently debating side mount or rear mount turbo
What did you do with the brake servo? Did it clash with the side mount turbo?
I’m looking at going down the emerald ECU route at the moment and creating a selection of maps
What are your plans for the cylinder head ?
I have not been planning on doing a gearbox rebuild, do you think the standard A+ box can deal with 150 - 180
The new gears you got look amazing but £700 is a big chunk of money
#62
Posted 05 March 2019 - 12:36 PM
Looks really good nice project
If you're not going above 180bhp, you don't need anything special, the 21253 machined for low compression works well. The standard box will take 150/160 as long as you don't rag it in first all the time.
#63
Posted 05 March 2019 - 02:21 PM
Hi Cam,
You do need to ditch the brake servo to accommodate the side mount manifold but it is pretty simple using the yellow tag brake master cylinder with a few other bits.
http://minispares.co...sic/GMC227.aspx
Cylinder head will be going to Turbo Phil to work his magic. As I mentioned in another post I am looking for a compression ratio of around 8.50 so with my +20 10cc pistons the head chambers need to be around 27cc according to this handy calculator.
https://jscalc.io/ca...RNEglVkKLQir11T
The sky is the limit with Mini parts, I decided to go for the Evolution gear set because I didn't want the constant whine from the straight cut set but they will do almost the exact same job for half the price.
http://www.minispare...ic/C-STN39.aspx
As Steve says you can build a good spec turbo engine for a lot less but my thinking is that saving a few quid here and there probably isn't worth it in the long run. Build it once and build it properly!
Cheers,
Jamie
#64
Posted 05 March 2019 - 04:52 PM
Might go for a rear mounted as I prefer driving with the servo
A lot of guys on here go with Phil for head mods
I was planning on porting it myself but I no longer have the use of a flow bench to check flow
Need to decide if I’m going to go to the effort of valve & seat design or just improve port flow
I am not sure if the small tweets will be worth it on a turbo engine.
I need to find a mini to have a ride in with straight cut gears
I have not been in one before and I’m interested to see how whinny it really is.
I’ll be looking forward to seeing more pictures
I need to start making some progress
I have just sent off the subframes to be powder coated and the shell is in a split roast ready for me to weld all the new panels on.
#65
Posted 06 March 2019 - 09:07 AM
I do a lot of cycling so luckily my left leg is up to the task of non servo brakes! Haha
The straight cut gears aren't that bad to be fair and a lot of people love the noise they make but I will be driving for several hours to and from tracks and I know it would do my head in. Have a watch of some youtube videos if you can't find anyone locally.
Thanks mate, I've subbed your thread so looking forward to some updates from you too.
Cheers,
Jamie
Edited by jsyjamie, 11 March 2019 - 08:45 AM.
#66
Posted 22 October 2019 - 01:47 PM
Wow has it really been 7 months since an update?
Apologies for that but in my defense I have been driving the mini every day the weather has been nice!
Couple of issues, I had to replace the starter motor as the old one was knackered and last Friday the fuel pump gave up so that was a sign to get her off the road and start stripping ready for paint.
Thought I would give her one last wash first.
rps20191022_141753_542.jpg 68.51K 2 downloads
rps20191022_141907_928.jpg 66.01K 2 downloads
A local mini club member has given me a quote to do all the body work and respray the car inside and out if I strip her.
I have taken lots of pictures of all the rust patches, I won't bore you with them all but here is the worst of it.
Like most of my teens and early 20's it's a case of fit from far, far from fit! To be fair I've seen a lot worse...
rps20191022_142248_730.jpg 49.56K 2 downloads
rps20191022_142324_199.jpg 33.67K 1 downloads
rps20191022_142415_583.jpg 40.1K 0 downloads
rps20191022_142528_265.jpg 30.42K 0 downloads
rps20191022_142644_234.jpg 54.21K 0 downloads
The engine is still with Chris at Crafted Classics and is nearly finished.
So the plan from here is strip the car over the next couple of weekends then send it to the local paint shop. The guy is a one man band so it is going to take a while which will give me time to refurbish the front and rear subframes. I can take them down to him when he's finished, we can get it rolling then delivered back to mine.
Lets see how that goes! Ha-ha
#67
Posted 24 October 2019 - 09:28 AM
Some engine pictures, I'll let them do the talking...
facebook_1571908831165.jpg 72.99K 4 downloads
received_388520342063957.jpeg 45.16K 4 downloads
received_536999547066314.jpeg 52.88K 2 downloads
received_551755155641602.jpeg 48.88K 3 downloads
#68
Posted 24 October 2019 - 11:07 AM
Just come across your thread and the engine build looks absolutely mint! Cant wait to see it on the road.
#69
Posted 24 October 2019 - 12:04 PM
Thanks Ben, just subbed to your thread!
#70
Posted 27 October 2019 - 07:22 PM
That looks epic.
#71
Posted 28 September 2020 - 08:11 AM
Wow, nearly a year since the last update. That is a little bit embarrassing!
Things have been progressing albeit slowly...
I will put up a few posts up with lots of pictures bringing everything up to date.
Stripping the shell
This took a lot longer than it should due to working outside and a lot of the bolts were happy where they were.
test.jpg 52.93K 1 downloads
There was an ecosystem growing in one of my indicators
1.jpg 41.58K 0 downloads
Besides a few stuck bolts it all went pretty well and the engine was out
2.jpg 71.7K 0 downloads
20200111_153106_50381752987_o.jpg 42.89K 0 downloads
20200112_154233_50379256501_o.jpg 46.95K 0 downloads
Removed and stripped the rear subframe
20200222_141818_50381712367_o.jpg 53.92K 0 downloads
It was knackered so I ordered a new one
20200222_133844_50380834228_o.jpg 44.92K 0 downloads
20200415_165847_50381597056_o.jpg 47.61K 0 downloads
To be continued...
#72
Posted 28 September 2020 - 08:42 AM
The front subframe was in good nick so I gave it a clean with the power washer and sent it off to be powder coated
20200308_144635_50380849838_o.jpg 132.06K 0 downloads
Very happy with how it turned out!
20200312_165941.jpg 37.5K 0 downloads
Previously I had bought some Pro-tech coilovers and rear beam to do the conversion but speaking to a few people and having a think what I will actually be using the car for I decided to go back to traditional rubber cone suspension. Pro-tech shocks and rebuilt top arms ordered.
20200222_133232_50378563098_o.jpg 93.27K 0 downloads
Everyone loves a before and after cone picture
20200308_130904_50381727952_o.jpg 36.02K 0 downloads
Then it was just a case of putting everything together which went pretty smooth
20200326_150307_50380855778_o.jpg 37.74K 0 downloads
20200401_133443_50381759982_o.jpg 45.76K 0 downloads
Besides when you order 8 bolts and they send 6 black and two silver
20200308_132449_50381581981_o.jpg 33.48K 0 downloads
Font subframe now complete and good to go!
#73
Posted 28 September 2020 - 09:40 AM
Ecosystem in the indicator light was funny.
Love the powder coated front subframe and build up. Looks ace. I will be going the same way.
If you don't mind me asking how much did it cost to get your front subframe powder coated? I'm in the northwest of england.
Good work with the progress and posting an update.
#74
Posted 28 September 2020 - 11:41 AM
With everything going on I decided to give refurbishing and reaming the radius arms a go
20200307_115330_50380852008_o.jpg 76.4K 0 downloads
20200401_141533_50381772667_o.jpg 54.67K 0 downloads
I bought a reamer from ebay and followed Keith's (Classic Mini Workshop) video
I over reamed the first bushing but got the next two bang on. It was quite a difficult and messy job but another pretty useless life skill added to the list!
Then same as the front subframe it was just a case of putting it all back together
I bought the complete suspension kit from minispares and it is great besides the rear camber brackets. Not a fan at all so I will be ordering the KAD equivent
https://kentautodeve...er-toe-brackets
20200504_111510_50380898668_o.jpg 57.92K 0 downloads
20200527_074852_50381776757_o.jpg 36.89K 1 downloads
That was the rear subframe pretty much built up until it will go back on the car
#75
Posted 28 September 2020 - 11:43 AM
Thanks mate! Front subframe was quoted £120 but he did it £100 for cash which I was happy with. Most things cost more over here compared to the mainland but that should give you a rough idea...
