13Inch Wheels To 12’
Posted 27 September 2018 - 05:41 AM
Would the best option be to change to Cooper s 7.5 brakes or are there different options available?
Posted 27 September 2018 - 06:48 AM
Posted 27 September 2018 - 09:31 AM
It did think about the 10' might be a bit odd. I wasn't 100% sure if 12' would fit with the 8.4 set-up and it would probably to better suited. thanks for the information.
Posted 27 September 2018 - 08:18 PM
If you can afford it, the very best thing would be 'S' 7.5" discs and 10" wheels.
With 4.5" x 10" wheels you don't need wheel arch extensions which is an added bonus.
Posted 28 September 2018 - 05:44 AM
Hi,
If it's been cut out to fit sportspack arches and you change it to 10" wheels you'll need new wings and a front panel for it not to look like a 4x4.
Posted 28 September 2018 - 06:43 AM
Posted 28 September 2018 - 09:13 AM
Hi,
If you're thinking about the width overloading the wheel bearings, it's actually the offset of the wheels that makes the most difference. The same offset wheels in 6&7" width would only have 1/2" more on the front face, the inner won't affect the bearings.
