In-Line Fuel Filter
Posted 27 September 2018 - 05:25 PM
I have a John Cooper LE MPi classic mini which I’ve owned for a few years. The previous owner had a fuel boost valve fitted which I’ve only just got around to removing (I know I should have done it ages ago, they’re awful!)
The problem is I’ve replaced the boost valve with an in-line fuel filter and now the car won’t start. Previously it would start first time. It must be the fuel filter that’s the problem but why????? It’s definitely fitted the right way round and fills with fuel when the key is turned.
Anybody know what’s wrong? Thanks in advance.
Posted 27 September 2018 - 07:21 PM
Posted 27 September 2018 - 07:35 PM
Posted 27 September 2018 - 07:40 PM
Posted 27 September 2018 - 11:20 PM
Hi,
So if you took out a fuel pressure regulator why haven't you replaced it with another FPR?
Did it run ok and pass the MOT? If so I don't understand why you took it out in the first place?
Posted 28 September 2018 - 12:47 AM
as above what is regulating/maintaining the fuel pressure now? is the original fuel pressure regulator present and connected?
Posted 28 September 2018 - 07:16 AM
Posted 28 September 2018 - 07:18 AM
Posted 28 September 2018 - 07:33 AM
Posted 28 September 2018 - 09:27 AM
Hi,
Right then you need a standard MPI fuel pressure regulator or a universal sytec one which is 1:1 not 1.7:1
See which you can get hold of. Either will need some work to fit but the mpione won't need setting up.
Posted 28 September 2018 - 09:31 AM
Not surprised. You've probably had copious amounts of bore wash too.
Hi,
You won't get bore wash if it's setup right.
I'm using one to reduce fuel pressure at light load for the extra large injectors I've fitted.
Posted 28 September 2018 - 12:29 PM
Hi,
I'm aware. As the OP's wasn't set up, my concern is any internal damage.
Posted 29 September 2018 - 04:28 PM
Posted 15 October 2018 - 03:01 PM
