Modification Choice For Road Use
Posted 28 September 2018 - 06:42 AM
I currently have a fully rebuilt 1275 cooper engine as per below spec and have a spare suck through supercharger kit. But I’m really concerned after reading story regarding blowing pistons etc with forced induction and the possible poor running of the suck through set up. Which frankly scares me after taking the time to rebuild an engine. I’m looking for between 90-100bhp for hopefully a once reliable engine.
Is the m45 suck through set up really that bad on low boost 6/7psi ? Am I going to be having reliability issue all the time ?
Current engine spec:
1275 cooper rebuilt engine ( honed, bearings,, rings ,water pump , oil pump etc )
Stage 1 kit ( maniflow etc)
MED ultralight ST1 clutch kit
Upgraded ally rad
Standard gearbox
Rebuilt hif44
73bhp at flywheel with 80ft I.b torque
Current supercharger kit :
Will aim for 8.5.1 compression
Suck through m45 Hif44 carb (Vmax )
Metro turbo distributor
90mm crank pulley ( speaking with Stuart at Vmax should be 6-8psi instead of the normal 110mm . Doing calculation it’s coming out at 8psi.
Posted 28 September 2018 - 09:19 AM
Hi,
If you want reliability then I'd go for a GT1752, intercooler, metro turbo carb and ECU controlled dizzy less ignition.
If you want to go all out have injection too.
Ignition and fuelling controlled by an ecu will protect your engine if done properly.
Posted 30 September 2018 - 08:30 PM
Don't be frightened, I have blown A series for almost 50 years and never had a melted piston, which I have had happen on full race engines.
Listening to other people's blowing problems, it seems that they claim that they are only aiming for a 20% increase in power, but go for 40% without preparing for it, and then wonder why things go wrong.
You have to get the timing correct for the rev range that you will be running at. DON'T RUN A WEAK MIXTURE. Some people say that you must run a rich mixture, which is helpful but wasteful. Remember that a suck through set up blends the load, which produces a better burn.
If you are frightened, pass the buck to an expert.
Posted 01 October 2018 - 06:53 PM
I do prefer a turbo, but as you have the vmax kit it would be a wise way to go. As bat says I would definitely get a marble ignition system on there too.
Posted 04 October 2018 - 06:27 AM
On a fully rebuild engine on standard internals would it be ok to run low boost suck through 6-8psi with a compression of 8.5.1 ? With an updated turbo clutch plate / cooling and x pin diff .
Could someone help me on how to measure the piston/ block deck height please ? As I’m trying to work out my compression.
Could you use a straight edge with a feeler gauge ?
I also need to remove the diff to change to x pin, I’ve had a look through the forum and people have said it’s possible with engine in situ by moving it forward ?
Posted 04 October 2018 - 06:55 AM
Hi,
I'm aiming to put your 6-8 possibly 10 psi into a bog standard MPI engine!
I'd say don't lower the compression unless you're absolutely sure you need too.
It may be that you have to with a supercharger or if you used an ECU to control the ignition you wouldn't need to?
I've no experience with a supercharger but the turbo is well underway.
Posted 04 October 2018 - 09:39 AM
with an 8.5:1 ratio, you could run good quantities of boost! Mine's a similar CR and I intend to run 15psi.
Posted 04 October 2018 - 10:33 PM
Would standard internals be reliable on low boost ?
Posted 05 October 2018 - 07:15 AM
This is the best compression ratio calculator I've found.
https://jscalc.io/ca...RNEglVkKLQir11T
Not sure who wrote it so can't give any credit unfortunately...
Posted 05 October 2018 - 08:35 AM
Posted 05 October 2018 - 03:15 PM
You'll be fine.
Will you be running a wideband lambda or any kind of knock monitoring?
