See this on farce book ...
name a part/ component that hasn't changed the entire life of the classic mini (saloon)
I will go first ...
Tail light bulb
Tie rod
bonnet pin & spring
Posted 30 September 2018 - 11:12 AM
I will go first ...
Tail light bulb
Tie rod
bonnet pin & spring
Posted 30 September 2018 - 11:16 AM
roof skin (saloon)
Edited by nicklouse, 30 September 2018 - 11:17 AM.
Posted 30 September 2018 - 12:37 PM
boot hinges
Posted 30 September 2018 - 12:49 PM
Headlights
Posted 30 September 2018 - 12:50 PM
Rust
Posted 30 September 2018 - 07:10 PM
Roof panel,
Front wings (ignoring the side indicator hole)
Bumpers
Posted 30 September 2018 - 07:54 PM
Posted 30 September 2018 - 09:25 PM
Castle nuts
No, they changed from 1-5/16" to 34mm at the end of production.
Rear bins I think remained the same, even on the variants.
Posted 30 September 2018 - 10:08 PM
Won't the roof have changed with the different drainage from the gutter when the plaggy trim was introduced?
There have been various headlights - sealed beam, tungsten bulbs, halogen, Clubby ones without sidelight provision. Maybe the headlamp bowl seals though?
Sorry Cooperman, Clubman bumpers must've slipped your mind and the MPI's had rolled ends to satisfy C&U regs over sharp bits.
How about radius and upper arm pins and hand brake quadrants?
Posted 30 September 2018 - 10:37 PM
the guttering in not part of the roof panel i have taken off a 59 roof and fitted a brand new late 90s roof. the roof panel ends in the gutter.
Posted 30 September 2018 - 11:05 PM
My mistake, do I have to think of another one now? Rocker studs (does that count as 2 or 4 )
Posted 01 October 2018 - 12:54 AM
That'll only be 2 !!
Posted 01 October 2018 - 04:18 PM
vertical seam covers?
Posted 01 October 2018 - 09:04 PM
Handbrake quadrants are different on a hydro car.
Posted 01 October 2018 - 11:55 PM
Hi,
Engine mounts.
