Hey guys, I have just purchased a 1981 Morris Mini that hasn't been started in 11 years. engine has oil and everything but when i turn the key i can hear it trying to start but the radiator fan and the belt does not move at all and there is no spark. anyone know what i should change to get the car started. Thanks.
1 reply to this topic
Posted 01 October 2018 - 07:10 AM
Posted 01 October 2018 - 07:31 AM
I'd turn the engine over by hand first, to ensure it turns nicely.
Then have a fully charged, known good battery hooked up. If you're using one that's been sat for 11 years, it'll be knackered.
Edited by Wiggy, 01 October 2018 - 07:32 AM.
Mini Technical Sections →
Problems, Questions and Technical →
Piston Rings - A-Series 998 Engine - Help RequiredStarted by WanaGo , 18 Apr 2024 engine |
Exhaust Choice 45Dcoe - Rc40?Started by lachlan1275gt , 13 Apr 2024 engine |
1071 Main Bearing Caps.Started by 246jaenick , 02 Apr 2024 engine |
Misfire - Ignition Fault Or Fuel Problem?Started by derekaka2sheds , 01 Apr 2024 electrical, engine |
Which Rocker ArmsStarted by mark the diver , 30 Mar 2024 engine |
