Spot Lamp Colours ?
leepol83
, Oct 04 2018 06:47 PM
37 replies to this topic
#16
Posted 06 October 2018 - 04:27 PM
That’s a good idea ? cheers guys
#17
Posted 06 October 2018 - 05:41 PM
Just one last thing do the driving lamps come on with the normal lights or just when on high Beam ?
#18
Posted 06 October 2018 - 05:45 PM
Just on high beam.
#19
Posted 06 October 2018 - 05:54 PM
R right that’s where I’m going wrong then ? not tried high beam ?
#20
Posted 06 October 2018 - 06:06 PM
Oops! ??
#21
Posted 07 October 2018 - 07:57 PM
Hi all right been down today to have a play with my new meter, looks like I have no power to any of the lights, now someone had removed them before and just poked the wires behind the grill, would they have disconnected somewhere maybe relay or fuses ?
Thanks in advance
Thanks in advance
#22
Posted 07 October 2018 - 08:10 PM
I'll PM you some pics of the diagrams etc.
#23
Posted 07 October 2018 - 08:54 PM
than you Wiggy
#24
Posted 12 October 2018 - 06:11 PM
Hi chaps back on this again!!! Got the spots working no problem wired the lived into the spot lamp and done nothing with the earth but still work fine, but can’t get the fogs working ?
I’ve found the 3 yellow relays located driver side in the engine bay, can anyone tell me which one is for the fogs please, although I have swapped them all about and still no joy, but stuck in this is there any hidden fuses someone may have removed
#25
Posted 13 October 2018 - 12:25 PM
Have you checked if there's a fuse in the inline fuse holder? Left hand side of engine bay (as you look under the bonnet).
Little Black oblong thing. 15A.
#26
Posted 14 October 2018 - 09:52 AM
Thanks Wiggy, I’ve literally just figured it out, bit funny really but I realised that the fogs won’t operate whilst the lights are on normally only Whilst the side lights are on ha ha!!! Assuming that’s right ? ?
#27
Posted 14 October 2018 - 10:54 AM
Fogs should work with normal headlights on, but go off if using high beam.
#28
Posted 14 October 2018 - 11:28 AM
Indeed. The fogs should operate on dipped beam and side lights.
Pretty sure mine used to stay on with high beam though. Could be wrong. I've removed them so can't check.....
#29
Posted 14 October 2018 - 07:24 PM
You're correct, my error, they stay on with the high beam. Wiring diagram shows the link remains in place when the high beam is selected (unless I'm reading it wrong!):
Posted 15 October 2018 - 07:06 PM
Thanks guys just to clarify if I turn the light to the first click and turn the front fog switch on they work but if i turn the lights to the second click (normal lights on) the fogs don’t work is this right then ?
