Rc40 Exhaust Manifold, 2 Core Radiator And Fuel Pump.
3 replies to this topic
#1 Firephoenix
Firephoenix
  • 13 posts
Posted 06 October 2018 - 10:15 AM
For sale I have due to owner no longer needing after some upgrades;
RC40 maniflow mild steel exhaust manifold (Minispares C-STR816), 3 years old and has done about 600 miles, slight surface corrosion(the pictures don’t do it justice), has the lower bracket but missing the support tag, but this can be either made or bought separately from Minispares for about £5 (C-AHT98-only need the tag off this). Got plenty of life in it, £20. Collection only from Swale area of Kent.
Attached File  781DB4B0-3548-4705-9CE8-40190A82C743.jpeg   239.43K   1 downloadsAttached File  D0D3D287-39DB-41FD-89E5-1E9B5B1C864B.jpeg   160.21K   0 downloadsAttached File  80FCA45D-1DE4-441D-A415-8476E8EEB18C.jpeg   233.29K   1 downloads
Minispares 2 core performance radiator (C-ARA4442)
Again done about 600 miles, and is 3 years old, no leaks when removed, includes radiator cap (15lb). I’ve flushed it through until clear water appeared, quite clean internally from what I can see.
Obviously due to the fragility of radiators it is collection only, It probably looks better in pictures than it is but still got plenty of life in it. £35. Swale area of Kent.
Attached File  86B1D0BC-02CC-460F-A307-949AD700BE54.jpeg   149.29K   0 downloadsAttached File  5050A3D5-DFAC-47AA-89F3-C78DFD1CAD92.jpeg   138.35K   0 downloadsAttached File  E58C982B-BD15-41FE-9AA0-FFAC8E3AF530.jpeg   119.36K   0 downloadsAttached File  70787FC7-87A3-4FD0-BC69-FE47FCAE33C8.jpeg   133.91K   0 downloads
Mechanical Fuel pump non genuine Minispares AZX1818MS,
It was taken off as owner wanted genuine SU mechanical pump fitted while manifolds off, it has the spacers and gaskets (but I would recommend new gaskets), it sucks and blows and is about 3 years old with approximately 600 miles use. Collection only as it whiffs of petrol, Swale area of Kent £8.
Attached File  AB6CFE5D-ADD8-47D2-9679-F747AD529173.jpeg   218.94K   0 downloadsAttached File  C6BBE1CB-CC32-4A98-9C41-665D45369E8A.jpeg   215.34K   0 downloads
PM if you need any further details, not here to fool anyone but not about to give it all away, so I kindly ask please don’t turn up with £20 expecting to buy it all, as it’s already quite fairly priced.
Please use the Minispares part numbers to work out if they will fit your mini.
Thanks for looking.
Edited by Firephoenix, 21 October 2018 - 07:07 AM.
#2 Firephoenix
Firephoenix
  • 13 posts
Posted 21 October 2018 - 07:09 AM
Just a little bump, anyone interested?
Edited by Firephoenix, 21 October 2018 - 07:10 AM.
#3 rolesyboy
rolesyboy
  • 34 posts
Posted 21 October 2018 - 11:32 AM
Message sent
#4 floormanager
floormanager
  • 620 posts
  • Local Club: Mini Club Sussex
Posted 21 October 2018 - 05:19 PM
hI there, I'm interested in the radiatior please.
Paul
