Spi Rad Sensor Colours
Posted 07 October 2018 - 07:01 PM
Posted 08 October 2018 - 06:42 AM
Hi,
Should be light green with a black stripe and a plain black.
Fan has a black with a green stripe and again a plain black.
Wiring diagrams are available on this very forum
Posted 08 October 2018 - 07:06 AM
Posted 08 October 2018 - 07:24 AM
Hi,
Seized fan would be my first guess. Try unplugging it then bridge the switch wires.
If it blows the fuse then, probably a short in the wiring.
Posted 08 October 2018 - 08:33 AM
Posted 08 October 2018 - 05:36 PM
Posted 14 October 2018 - 06:57 PM
Theres a basic guide to setting the steeper motor by turning on ignition and pumping throttle pedal 10 times then switching off ignition, some say not to use throttle pedal but go direct to the motor itself with same procedure of opening and closing 10 times...
Posted 14 October 2018 - 09:04 PM
Urban myth - this doesn’t set anything I do wish people wouldn’t repeat this.Theres a basic guide to setting the steeper motor by turning on ignition and pumping throttle pedal 10 times then switching off ignition, some say not to use throttle pedal but go direct to the motor itself with same procedure of opening and closing 10 times...
To set up stepper motor you need Testbook, T4, Sykes Pickavant ACR plus Rover V3 pod or Crypton ACT systems.
Cable set with lost motion linkage gaps - see Haynes Manual or similar
FS
