Spi Megajolt
Best Answer RooBoonix , 13 October 2018 - 09:56 PM
Are there any plug and plug standalone ECUs for the SPI cars?Meagjolt is just ignition
Check out specialist components, I believe they make one called the Typhoon Go to the full post
Posted 13 October 2018 - 08:01 PM
Is anyone running a megajolt in their spi mini? How difficult is the install? And are they easily mappable?
Cheers!
Posted 13 October 2018 - 08:36 PM
Posted 13 October 2018 - 08:59 PM
There wouldn't be any point. The ECU already does what the Megajolt would do.
You can map the megajolt but the SPI ECU is not mappable, I've been looking at it for mine and wondered if there would be any benefit so I will be following this thread.
Posted 13 October 2018 - 09:00 PM
Posted 13 October 2018 - 09:14 PM
Posted 13 October 2018 - 09:44 PM
Posted 13 October 2018 - 09:56 PM Best Answer
Posted 14 October 2018 - 12:33 AM
I believe Delta 400 is the ECU that SC now provide. They do have a kit that provides only an ECU for the SPi.
I think it depends on one's definition of plug and play, perhaps someone who has the SPi replacement ECU installed will reply.
Posted 14 October 2018 - 08:53 AM
Edited by Minimax234, 14 October 2018 - 08:53 AM.
Posted 14 October 2018 - 09:16 AM
if you want to spent money :http://www.mini-coop..._classic_m.html
Posted 14 October 2018 - 10:24 AM
I had a quick look at this before and thought it looked expensive! Do you know what the price for one is?
Posted 14 October 2018 - 10:27 AM
Posted 14 October 2018 - 11:31 AM
Posted 14 October 2018 - 12:29 PM
Hi,
I'm sure the website said it was €699 when I looked earlier.
Posted 14 October 2018 - 03:14 PM
Maybe it’s better to look Into some other modifications first.
It’s a standard SPI I have so maybe I should look at a modified head, LCB manifold, K&N filter and 1.5 rockers. Any idea what this would produce? Would the stock ECU handle it ok?
