Mini Windscreen Curvature?
3 replies to this topic
#1 Mowogler
Mowogler
    Starting My Mini Up
  • 2 posts
Posted 14 October 2018 - 09:10 AM
Hi there,
I’m building a classic kit car, a Rochdale GT, originally designed in 1958 and need to cut down a windscreen to fit it. I’m widening the body shell to fit the donor chassis better so the original screen won’t work.
Laminated glass can be cut down so a mini screen would make a good starting point if the curvature is right.
My question is what is the curvature of the mini front windscreen. If you put a straight edge across the screen inside from edge to edge what is the gap between the edge and the windscreen at the centre? I think it tapers so the gap would be smaller at the top than the bottom?
Thanks in advance
Phil
#2 motorwise
motorwise
  • 18 posts
Posted 14 October 2018 - 10:53 AM
the front screen is out of mine at the moment i'll measure it tomorrow for you when i'm at the garage (hopefully i'll remember got a lot of mot's in tomorrow)
#3 Mowogler
Mowogler
    Starting My Mini Up
  • 2 posts
Posted 14 October 2018 - 03:19 PM
Thanks Motorwise. That would be a great help.
#4 motorwise
motorwise
  • 18 posts
Posted 16 October 2018 - 06:39 PM
laid screen face up on flat surface ..... measured four and a half inches bottom of the glass and three and a half inches top of the glass .... at centre down the flat surface ... hope it helps
