Posted 20 October 2018 - 12:54 PM
Posted 20 October 2018 - 12:57 PM
Any idea what you have fitted currently?
I have a Fletcher Alloy two core radiator - they're pretty good for the price point but an alloy rad may be overkill depending on your setup, what engine and state of tune are you running?
Posted 20 October 2018 - 01:04 PM
I'm running a Fletcher too! Does fine on my highly modified 1330!
Good rad for the price, and includes the silicone hoses if you get the bundle. Although I think you will need a hose reducer for the heater outlet from the bottom hose like I did!
Posted 20 October 2018 - 01:21 PM
No clue have a have running now but I have a standard 1275 but I want to go supercharged in the future
Posted 20 October 2018 - 01:22 PM
Okay mate, fletcher rad sounds like the way forward, thanks
Posted 20 October 2018 - 05:15 PM
A quality 4 Core Copper Radiator will be fine.
Posted 20 October 2018 - 10:32 PM
Posted 22 October 2018 - 09:59 AM
Mini spares special 2 core with the switch for your fan. I use it on my turbo.
Mini Technical Sections →
Problems, Questions and Technical →
Piston Rings - A-Series 998 Engine - Help RequiredStarted by WanaGo , 18 Apr 2024 engine |
Exhaust Choice 45Dcoe - Rc40?Started by lachlan1275gt , 13 Apr 2024 engine |
1071 Main Bearing Caps.Started by 246jaenick , 02 Apr 2024 engine |
Misfire - Ignition Fault Or Fuel Problem?Started by derekaka2sheds , 01 Apr 2024 electrical, engine |
Which Rocker ArmsStarted by mark the diver , 30 Mar 2024 engine |
