Engine Swap Merry Dance
Posted 21 October 2018 - 12:45 PM
I'm going to do an auto to manual swap in my garage as by block and tackle hung from a beam. I was intending to lift the engine and then roll the car back a metre out of the garage, then winch up the new engine and roll the car back in and drop new engine..... simple heh? Probably not.. .
Am I best disconnecting top and bottom ball joints on both sides, freeing both drive shafts lifting engine and reconnecting all 4 ball joints (and both track rods) to roll the car?
Or can I get away with splitting top ball joint only?
Or should I make up some sort of dolly to roll the front of the car on so I'm not faffing doing up ball joints just to move the car?
What are my options here? I've not done this before so dont know what works best and is simplest?
Just a note.. I don't have a driveway as such or flat area for an engine hoist so I have to do it in my garage.. .
Any advice?
Cheers.
Posted 21 October 2018 - 12:59 PM
Hi,
If you're swapping the subframe too leave the engine in and lift the car off the subframe.
Wheel next subframe in and lower car...
Posted 21 October 2018 - 01:05 PM
Posted 21 October 2018 - 01:26 PM
A cheap metric and imperial tap and die set is great for cleaning the threads, and makes it much easier to do them back up.
Posted 21 October 2018 - 02:14 PM
Also.... shaft out of pot joint or pot joint off of diff?
Posted 21 October 2018 - 02:23 PM
Pot joint off of the diff. A bolster chisel pivoting on a ½" socket sat on a diff side cover bolt, then a sharp tap with a hammer works well. A tip I read on here.
Posted 21 October 2018 - 02:57 PM
Posted 21 October 2018 - 04:41 PM
Posted 21 October 2018 - 05:00 PM
Hi,
Ball joints in just put the nuts on loose. Tre the same.
Posted 21 October 2018 - 05:39 PM
Posted 22 October 2018 - 09:06 AM
It's possible on at least one side, but make life easy for yourself and split both. I did it just the other day. You'll probably need a splitter.
Sorry wiggy. Missed this..
I've got a splitter so I'll do both as suggested... good tip about the socket. Avoids damaging the diff case I guess?
Posted 22 October 2018 - 09:18 AM
The splitter invariably damages the rubber boots - which is fine if you are going to replace the ball joints, not so good if they don't need doing.
Posted 22 October 2018 - 09:54 AM
Posted 22 October 2018 - 01:32 PM
