Exhaust from Minisport
Classic Mini Van, Estate and Pick-up side exit exhaust system, featuring twin silencers and polished stainless steel tailpipe. Designed with performance in mind, each exhaust system uses mandrel-bent steel tubing for maximum flow and perfect fit, whilst the SuperFlow silencers boast a straight-through design.
The SuperFlow ST400 system is designed for fitment to LCB Manifolds and comes with 1.75" bore
A free flow design in a refined package, fitting an exhaust from the Mini Sport Superflow range to your Mini will result is a strong performance tone during spirited driving, a mellow growl on the highway, with a boost in performance. Developed and tuned over nearly 50 years the Superflow Mini exhausts will give you the works without the expense.
This has done approx 15 miles .... not kidding ! Changed it because got an upgrade for bigger exhaust .
As photos - nearly nearly new
Due to weight size and packaging buyer will have to collect from NE312SF
Can deliver if local
£65 Ono
Van Estate Pick Up Exhaust
longtimenomini
, Oct 22 2018 05:36 PM
No replies to this topic
