Hey all
So after 2 months of waiting, my mechanic finally got around to checking whats wrong with my mini.
It failed the MOT for bad emissions - 7.5 CO and 2500HCs.
I personally thought that it might have been a badly adjusted carb, possibly the wrong needle, and wrong mixture, so I brought it to a guy that has done some classic cars for friends.
He finally got to in last week and sent me a text saying that the engine only produced 6Bar (87psi) compression across all 4 cylinders.
He also wasnt able to get the CO value below 5% and HCs below 1000 (I think the legal limit is 3.5% and 600 here in Austria, receptively)
He also said that the ignition timing was "completely off" - although the car ran pretty well before without hiccups.....hard to believe but ok...
My question is what could cause such low compression across the board? I understand that if 2 cylinders had a lower compression vs the other 2, then the head-gasket would have blown, but all 4?
Also, asking for some advice here. Should I bring the car to a specialist and have him do a complete runthrough and get my car MOTd and registered (will cost a bit), and have him do multiple things at once? What I mean by this is: if he has to swap the headgasket or open up the engine, should I just wing it and do a porting job/rocker changes/valve job etc.
Im willing to spend probably around 2k to get the car MOTd, registered, "fixed", tuned, etc.
I already have a stage 1 kit installed so whats the "norm" when it comes to engine work and upgrades inside the engine?
