As title suggest, I'm finding engine oil on the underside of my distributor body, dripping on top of the starter.
New distributor a few weeks back, leak started then. But doesn't seem to be coming from where the dizzy meets the block, rather the dizzy body itself.
I can make up a gasket for the distributor-block connection, but fairly sure this is not a normal place for one, right?! Since theres an oil 'O' ring on the spindle
In terms of engine oil pressure, I think its OK - breathers are clear, doesnt overheat, and if it was a pressure issue, I'd have expected it to burst out of the existing small leak at the gear rod selector seal!
Had a quick search of the forum and not found a thread on this leak point - is it common? Whats the best solution?
Cheers, Peter
