can help me with the headlamp levelling wire codes?
i have
GREEN BROWN BROWN
WHITE WHITE-RED YELLOW
THANKS
Posted 07 November 2018 - 07:57 PM
i have
GREEN BROWN BROWN
THANKS
Posted 07 November 2018 - 08:11 PM
colour.JPG 39.31K 6 downloads
level.JPG 40.43K 8 downloads
to be honest a bit more car info would help.
Edited by nicklouse, 07 November 2018 - 08:12 PM.
Posted 07 November 2018 - 08:26 PM
Hola,
Buena noches.
Most of the colours you have are not head light leveling. See the diagram below.
Estoy en Pinoso.
Gracias
Screenshot_2018-11-07-21-17-35-306.jpeg 31.25K 7 downloads
Posted 07 November 2018 - 08:27 PM
Hi,
Nick beat me to it!
Posted 07 November 2018 - 08:31 PM
there is also the German version that uses different colours as well see in here http://www.theminifo...agrams-redrawn/
Posted 09 November 2018 - 10:03 AM
like I have already said we need more info model year etc.........
Posted 09 November 2018 - 10:23 AM
i don´t know i bought the levelling on ebay if not i´ve already said, and im doing a handmade wiring... but thanks
Edited by ochumi, 09 November 2018 - 11:28 AM.
Posted 09 November 2018 - 10:49 AM
They are very odd colours to go to a Headlamp switch in a Mini (or indeed any car following Lucas conventions)
Normally:
Brown - permanent live
White - Ignition live
White/Red - Switched starter motor trigger
Green - fused accessory live
Yellow - not sure!
I would suggest the plug you have been given, although the right type for the switch, has actually been cut from elsewhere on the loom and should connect to the ignition barrel.
Posted 09 November 2018 - 10:59 AM
i don´t know i boght the levelling on ebay if not i´ve already said, and im doing a handmade wiring... 4 but thanks
Then time to get your multimeter out.
Posted 09 November 2018 - 01:55 PM
yep but on diagram i see 4 conections and i have 6...
Posted 09 November 2018 - 07:08 PM
Hi,
That's a plug from a metro heater fan switch!
You'll need to look in the mpi workshop manual to find out which position the wires go into the socket so you can wire it up to the colours you have.
Posted 09 November 2018 - 09:22 PM
Posted 09 November 2018 - 11:14 PM
Hi,
Posted 10 November 2018 - 06:39 AM
