Mpi Problem For France
9 replies to this topic
#1 Emerson 76500
Emerson 76500
    Starting My Mini Up
  • 3 posts
Posted 08 November 2018 - 05:17 PM
Hi i'm a french man and i have a RHD mini with the problem .
When i road at quater of hours my car breackdown ,and arrive to return at home but with the engine at 1000round/ minute and it's impossible to accelerate ,and when i let sleep i go tomorrow the car start and drive perfect .
i change a lot of parts :
- complet system ecu
- engine loom
- all sensor on the engine except the camshaft sensor
- all parts of injector
-new ignition
- new fuel filter
- new coil
- new plug and loom plug
And when the breakdown arrive my needle temperature of water falls at 0 even the water sensor is disconnect.
If you have a solution i'm listen or old diagnostic for this car if you have a link
thank you read you soon
#2 cal844
cal844
  • 9,488 posts
  • Local Club: TFMOC
Posted 08 November 2018 - 06:36 PM
So it's an intermittent high idle at start up? 1000 rpm is an ideal idle setting for an a series
#3 mab01uk
mab01uk
  • 11,804 posts
Posted 08 November 2018 - 10:32 PM
Some information here that might help.
MPi Electronic Diagnostics - Car Mechanics June 1999
http://www.theminifo...haps/?p=3508308
Edited by mab01uk, 08 November 2018 - 10:33 PM.
#4 Wiggy
Wiggy
  • 1,036 posts
Posted 08 November 2018 - 11:37 PM
I would hazard a guess that the main ECU earth point needs cleaning. It's on the bulkhead to the left of the brake servo.
#5 genpop
genpop
  • 474 posts
Posted 09 November 2018 - 12:01 PM
your questions will be answered better here  :Injection Mini Specific - SPi/MPi
#6 Emerson 76500
Emerson 76500
    Starting My Mini Up
  • 3 posts
Posted 24 November 2018 - 04:36 PM
Sorry it's an MPI i don't says it in my post
#7 Spider
  • 13,935 posts
Posted 24 November 2018 - 05:11 PM
Also, it would appear you've been clicking on the 'Report to Moderator' button to reply.
You can type a reply in the big box below, then click on the 'Post' button ;D
#8 MacGyver
MacGyver
  • 1,027 posts
Posted 24 November 2018 - 08:31 PM
I'd check the earth too as Wiggy said.
(mise à terre, plein de câbles brun fixé par un écrou)
Ben
#9 Mini BO MPI
Mini BO MPI
    Starting My Mini Up
  • 4 posts
Posted 21 December 2020 - 10:20 AM
- engine loom
-new ignition
- new fuel filter
- new coil
Saut,
As tu trouvé une solution à ton problème ?
De mon coté, je cherche un outil de diagnostic ...
Merci,
Michaël, de Rouen.
#10 cal844
cal844
  • 9,488 posts
  • Local Club: TFMOC
Posted 21 December 2020 - 05:24 PM
You can buy the diagnosis cable and USB to phone USB as required from Ebay or Amazon.
Here is the MEMS 1.3 AND 1.6 LEAD (EDIT : I believe the MPI is a different ECU plug.)
https://www.ebay.co....e-/303464172974
You then need the MEMS Diagnosis Application that you can get for free
Search MEMS_Diag_Lite in App store
Photo included of the Android version
Edited by cal844, 21 December 2020 - 06:14 PM.
