Rod Change Into Remote Floor
6 replies to this topic
#1 Zeemax_Mini
Zeemax_Mini
  • 57 posts
Posted 09 November 2018 - 08:45 AM
I have a rod change box which I need to fit to my remote floor and I've seen the adapter brackets which seem to only be available from the USA. Just wondering if this is the best way to go or if there is a cheaper method?
Cheers, Dom
#2 nicklouse
  • 19,067 posts
Posted 09 November 2018 - 08:52 AM
if you cant fabricate it yourself then there not really another option.
not seen the kit but done it the other way many times.
#3 Spider
  • 15,878 posts
Posted 09 November 2018 - 09:34 AM
There is also the Factory Bracket that was used in all Australian Production after the Rod Shift was introduced.
The floors in our cars were essentially all MKI to the end of production.
#4 evil ewok
evil ewok
  • 354 posts
  • Local Club: A's of Herts
Posted 09 November 2018 - 11:11 AM
http://minispares.co...|Back to search
#5 Zeemax_Mini
Zeemax_Mini
  • 57 posts
Posted 09 November 2018 - 05:06 PM
Thank you all so much! Had searched for a UK supply but not had any luck, that works out a bit cheaper than importing and should be much quicker.
Cheers :)
#6 nicklouse
  • 19,067 posts
Posted 09 November 2018 - 06:11 PM
Chris did that use rubber bobbins if so what size (height)? and how many?
#7 Spider
  • 15,878 posts
Posted 09 November 2018 - 06:52 PM
Yes, Nick, it did.
It uses 2 x GEX7251 Cotton Reel Mounts, the same that's used down the back end of the Exhaust Pipe. I've not measured the height of them, but at a guess, they'd be around 1-1/4" tall.
