I Have My Engine Out - Any Top Suggestions For Jobs To Be Done
Posted 09 November 2018 - 04:28 PM
Im definitely doing the clutch.
Any other essesntials / suggestions. Ill paint the block and head of course. Thank you
Posted 09 November 2018 - 04:50 PM
Diff output seals, rod-change seal, rod-change bushing. Not much else that's difficult to do with the engine in unless you're going to go a bit deeper and, for example, refresh the diff or change the timing chain as well.
Posted 09 November 2018 - 04:58 PM
Ideal time to fit a new cam, if that's your poison.
Posted 09 November 2018 - 05:07 PM
New main and big-end shells are inexpensive and worth changing, especially if the engine has done a fairly high mileage.
Re-lap the valves and fit new valve stem oil seals.
Posted 09 November 2018 - 05:10 PM
Resist taking anything off, such a dizzy and leads.... anything that will help you in advance of having to start another thread later called... my SPI won't start. :)
Posted 09 November 2018 - 05:55 PM
Posted 09 November 2018 - 06:19 PM
Water pump and flush cooling system and heater matrix
Posted 09 November 2018 - 06:47 PM
Ac
Posted 09 November 2018 - 09:05 PM
Rebuild the engine. duplex timing gear, kent 266 cam, modified cylinder head, quaife atb diff ect. Quite expensive, but it would make the car MUCH better to drive.
Posted 10 November 2018 - 12:22 AM
When.you.do.the.clutch.its.worth.changing.the.primary.gear.seal.at.the.same.time.
Posted 10 November 2018 - 04:16 PM
That would make it go very well. The only thing I would not do is to fit a limited slip diff. They can be hard work on the road and unless you expect to be doing what would be wheel-spin acceleration all the time without one they are an expensive and unnecessary item. However, a cross-pin diff is a good idea for a heavily modified car.
From another thread, the EVO001 cam might be a better option if a cam change is anticipated.
Posted 10 November 2018 - 07:14 PM
Not sure how good the emissions are with 266 or evo001 cam in an SPi for the MOT
I'm with Cooperman you don't need an LSD
When you do the clutch set the end float on the primary gear and don't forget the trust bearing
Posted 10 November 2018 - 08:36 PM
Posted 10 November 2018 - 10:31 PM
Wish a rebuild was in the budget
Posted 10 November 2018 - 10:32 PM
