De-Rusting
Posted 08 August 2004 - 08:27 AM
Posted 09 August 2004 - 04:56 PM
Where zactly R the holes U ned 2 fil? If U cant weld U ned 2 sand off awl th rust to bare metl. If U ken pas MOT w/o these repairs bean metl, use GRP 2 fix it. If U ned metl, use acid flux and a HOT soldering iron 2 install metl patches. Use plastix fill-r over the soldered patch 4 appearance. All acid flux must B removed B-4 filler applied. Dry sand 2 blend repairs, then prime from a spray can followed by mor sandin 'n top coat from a can.
I can't stand abbreviated, non-English web speak.
Posted 09 August 2004 - 05:24 PM
- in terms of the rust miniman5, then dklawson's advice is really good, make sure you get rid of ALL the rust before you do any repairs though else it will just rust through again in a very short time
Posted 09 August 2004 - 10:23 PM
I had to read it really slow, but top advice !
Posted 09 August 2004 - 10:37 PM
Ahh, my brain hurts!Miniman... I wrot ths so U'd understan it.
Posted 09 August 2004 - 10:38 PM
Posted 10 August 2004 - 07:49 AM
Posted 10 August 2004 - 08:29 AM
did you use a spray can, if you did then that might be the answer, no two cans of spray are perfectlly matched
Posted 10 August 2004 - 12:17 PM
Posted 11 August 2004 - 12:38 PM
