Peculiar Electrical Issue
25 replies to this topic
#1 Chris1992
Chris1992
  • 2,022 posts
Posted 10 November 2018 - 04:32 PM
Hi guys. So I'm nearing the end of the third rebuild of my Mini. Got it running nicely today an finished up on the wiring... or so I thought.
I'm having lots of issues with the lights, and it goes something like this. (I should also mention that I have a Wired-By-Wilson toggle switch kit fitted with LEDs on the end of the switches that light up when the switch is turned on)
The indicators work perfectly, including the green dash light
The hazards work fine all round, but the green dash light doesn't show, and neither does the light on the switch
The side lights work fine all round, but the light on the switch doesn't
The headlights don't work at all, including the switch light.
The high beams work only on the drivers side, and the blue dash light works fine.
I have no idea where the first place to start would be, so I figured I'd pitch it to you guys and see what you thought. Any help would be much appreciated!
Chris
#2 Wiggy
Wiggy
  • 1,036 posts
Posted 10 November 2018 - 04:39 PM
Year and model?
90% of electrical faults are earth based.
Otherwise it's time to break out those wiring diagrams.
Edited by Wiggy, 10 November 2018 - 04:39 PM.
#3 Chris1992
Chris1992
  • 2,022 posts
Posted 10 November 2018 - 04:45 PM
Year and model?
Sorry I should have mentioned. It's an 88 City E. The earths all seem to be fine which is why I figured I'd ask here.
#4 Wiggy
Wiggy
  • 1,036 posts
Posted 10 November 2018 - 05:01 PM
Did it work before hand?
I.E Has a fault developed, or could it be a wiring error?
#5 Chris1992
Chris1992
  • 2,022 posts
Posted 10 November 2018 - 05:06 PM
Yeah everything worked perfectly before the rebuild, it's only been off the road since August so not too long
#6 Wiggy
Wiggy
  • 1,036 posts
Posted 10 November 2018 - 05:15 PM
With so many faults, I'm tempted to say the fuse box is playing up. It's very prone to corrosion.
#7 Chris1992
Chris1992
  • 2,022 posts
Posted 10 November 2018 - 05:18 PM
hmm could be a good shout, it is the original one. I'll make that my first port of call tomorrow
#8 Wiggy
Wiggy
  • 1,036 posts
Posted 10 November 2018 - 05:21 PM
Have you checked the earth behind the dash?
#9 Chris1992
Chris1992
  • 2,022 posts
Posted 10 November 2018 - 05:44 PM
Not since I put it back a few weeks ago but I remember it being fine. Will check it again tomorrow when I pull the dash out again.
#10 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,781 posts
Posted 10 November 2018 - 07:30 PM
Have you asked David for his opinion Chris?
he is very helpful and knowledgeable. I'm sure he will have the solution.
#11 Bat
Bat
  • 903 posts
Posted 10 November 2018 - 07:35 PM
Hi,
First place I'd look at would be that clump of bullet connectors behind the grille.
There out there in all weathers and usually get very fuzzy.
Cheers  :proud:
#12 mm man
mm man
  • 398 posts
Posted 10 November 2018 - 07:59 PM
I would run a temporary earth from your earth points first to a know good earth or even to the negative side of the battery this way you can rule that one out first .
I had a intermittent fault once that turned out to be the main earth wire I had all sorts of odd issues and like yours it had only stood for a few months but was working fine before it went into storage.
Good luck
#13 Chris1992
Chris1992
  • 2,022 posts
Posted 10 November 2018 - 08:38 PM
I have to admit I don't know who David is mate  :shy:  :lol:
#14 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,781 posts
Posted 10 November 2018 - 09:50 PM
Wired by Wilson.
His name is David Wilson
#15 Chris1992
Chris1992
  • 2,022 posts
Posted 10 November 2018 - 10:21 PM
Wired by Wilson.
Aaaah yes I see! I should have known that lol. I'm not sure the problem is with the switch kit, but I may contact him anyway for his knowledge if I'm unable to fix this.
