Fast Road Suspension Geometry Figures
13 replies to this topic
#1 jackjewelljj
jackjewelljj
  • 241 posts
Posted 11 November 2018 - 06:06 PM
What’s everyone’s set up for fast road use front and rear with 10” wheels
#2 nicklouse
  • 17,945 posts
Posted 11 November 2018 - 06:09 PM
#3 Cooperman
  • 23,039 posts
Posted 11 November 2018 - 07:05 PM
I always set to the following:
Front:   1 to 1.5 deg neg camber
             2.75 to 3.5 degs castor
             0 to 1/16" toe out
Rear:    1/16" to 1/8" toe-in
             0 to 0.5 degs neg camber
Ride height:  Standard
#4 jackjewelljj
jackjewelljj
  • 241 posts
Posted 11 November 2018 - 07:37 PM
Cheers guys
#5 Pullstarter
Pullstarter
  • 36 posts
Posted 26 November 2018 - 11:28 PM
             0 to 1/16" toe out
Forgive my ignorance but I'm assuming the castor setting is positive? Also, the front and rear toe, is that per side or overall? Cheers.
#6 Cooperman
  • 23,039 posts
Posted 27 November 2018 - 12:22 AM
Yes, castor is always positive.
Toe is always across the wheels so is a total reading overall.
Those figures will be ideal for a 'not quite so slow' road Mini.
#7 Pullstarter
Pullstarter
  • 36 posts
Posted 27 November 2018 - 12:44 AM
Thank you, much appreciated :)
#8 Bobbins
Bobbins
  • 1,345 posts
Posted 08 May 2019 - 05:56 AM
What is considered to be "standard" height/rake for a late Mini on 12" wheels?
#9 paulrockliffe
paulrockliffe
  • 1,763 posts
Posted 08 May 2019 - 08:22 AM
And standard ride-height?  I remember when I looked for the factory ride-height figures the official diagram was missing a crucial measurement for working out the actual ride height.
#10 nicklouse
  • 17,945 posts
Posted 08 May 2019 - 08:36 AM
the only measurement that I have seen is for setting the hydro suspension. but the rake can be worked out as it does not matter where the Datum is.
but I have to ask why? and what year car?
#11 Bobbins
Bobbins
  • 1,345 posts
Posted 08 May 2019 - 09:12 AM
It's a '98 JDM Cooper running 12" x 5" wheels, and having fitted everything adjustable I need to start by getting the ride height correct then move onto the geometry settings as suggested above. I'm sure that changing the ride height later will change the geometry.
Stu.
#12 KTS
KTS
  • 2,271 posts
Posted 08 May 2019 - 10:58 AM
MokeSpiders' suggested method for setting the ride height :
http://www.theminifo...d/#entry3440131
#13 Reidbook
Reidbook
  • 36 posts
Posted 09 December 2019 - 08:08 AM
Would the Hillclimb setup listed be suitable for the road?
#14 nicklouse
  • 17,945 posts
Posted 09 December 2019 - 08:31 AM
a bit heavy on the steering with all that castor.
