Hi,
Looking for a bit of advice... Parked my mini up in the garage after it was running sweet as a nut with good oil pressure and then maybe a week later, started it up and had ZERO oil pressure.
I have both a mechanical oil pressure gauge showing 0PSI at idle and the oil pressure warning light which does not go out.
I've done a bit of reading and some suggested that it may be the oil pressure control valve stuck shut, so I ordered a replacement and fitted that today to no avail.
Any further suggestions of what the problem might be?
Cheers,
Marc.
Edited by Marc_mcq, 14 November 2018 - 06:47 PM.
