Does your friend have a Mini MPi?
About 1100rpm on a cold start. Then about 800 - 900rpm when warm. Approximately.
A slightly weak battery or past their best spark plugs or HT leads could possibly make her turn over a bit more before starting.
But I don't think you actually have a problem as such.
Hi
my friend also have a mini MPI and also I checked the reader in acr4
when I ask the mechanical he told me to check the spark no.3 if its black and I removed and it was really black
I changed all the spark with NGK bpr6es and the lead is the and original from rover.
he told me if the black comes to spark no. 3 that's mean the ideal valve control not working fine or need to adjust the throttle pin.
I will check with my acr4 to read the rpm once the car start, also the throttle position is 5.0 is that normal ?
Edited by Kubbar, 18 November 2018 - 04:35 AM.
