12G940 Valves
11 replies to this topic
#1 johnv
johnv
  • 494 posts
  • Local Club: FDMC
Posted 17 November 2018 - 10:12 AM
I’m looking to replace a couple of exhaust valves on this head .. I measured them at 1.209 in 30.71mm but I can’t find them anywhere .. length 3.52in single groove collet .. where could I get these? Thanks
#2 nicklouse
  • 17,944 posts
Posted 17 November 2018 - 11:48 AM
take them to your friendly engine builder and they will be able to supply and advise. ie replace them all and maybe replace guides and re cut seats. you may not be too far from Mr Dodd have a chat with him.
#3 Pigeonto
Pigeonto
  • 967 posts
  • Local Club: ISMOC
Posted 17 November 2018 - 02:49 PM
That's got to be Mini Spares' AEG594 surely?
If they must be 30.71mm but come slightly bigger  it's no problem at all to make them smaller, what ever size you like but I think I'd leave them as are.
#4 ACDodd
ACDodd
  • Mini Docs
  • 2,657 posts
Posted 17 November 2018 - 03:50 PM
They are these, your ones have likely been cleaned a few times I there life and are now Little small.
https://www.minispar...|Back to search
Ac
#5 DeadSquare
DeadSquare
  • 2,767 posts
Posted 17 November 2018 - 05:20 PM
Ac
Are those valves Nimonic?
#6 ACDodd
ACDodd
  • Mini Docs
  • 2,657 posts
Posted 18 November 2018 - 01:30 AM
Unlikely these will likely be plasma nitrided, which is better!
Ac
Edited by ACDodd, 18 November 2018 - 01:30 AM.
#7 johnv
johnv
  • 494 posts
  • Local Club: FDMC
Posted 18 November 2018 - 07:27 AM
Thanks!
#8 johnv
johnv
  • 494 posts
  • Local Club: FDMC
Posted 18 November 2018 - 12:20 PM
It is a 940 not a 163 though but I think it's quite an early one
#9 ACDodd
ACDodd
  • Mini Docs
  • 2,657 posts
Posted 18 November 2018 - 12:34 PM
Maybe it has thw wrong valves fitted, and it should have the normal 3.57" valves fitted.
Ac
#10 johnv
johnv
  • 494 posts
  • Local Club: FDMC
Posted 18 November 2018 - 01:01 PM
They seem to fit I’ll try to post a pic
#11 carbon
carbon
  • 2,590 posts
Posted 18 November 2018 - 05:03 PM
The shorter 'S' valves will fit in a 940 head, but be aware that the springs will go coil bound at lower lift.
If you're using high lift rockers or a radical cam profile then you will need to measure very carefully. If required the valve seats in a 940 head can be machined down to suit the shorter valves, but may you need to find a specialist machine shop for this.
#12 johnv
johnv
  • 494 posts
  • Local Club: FDMC
Posted 19 November 2018 - 09:17 AM
Pics .. I measured the combustion chamber at 18cc .. this seems quite small? although with dished pistons it looks like I could achieve a 10:1 cr ok
