A Mamba Wheel Question.
Posted 17 November 2018 - 07:10 PM
Two of them have the valves coming out of the silver rim and pointing outwards and the other four have the valves coming out from between the webs and point inwards.
The two have centrecaps that read “Halifax England” and the other four read “Of Halifax”
Are these Japanese copies ??
Posted 17 November 2018 - 08:04 PM
text below taken from the Mamba 6x10 notes on https://www.wheeldic...ry.net/10a.html
There are japanese copys around; the main difference is where the valve comes out of the rim, the "real" ones come out straight from the outer rim and the japanese ones come out of the black bit and on a 45° angle
Also available as 5x10"
...based on your description and the notes above you would appear to have 2 'real' and 4 japanese copies..
Posted 17 November 2018 - 08:34 PM
The set of four wheels have the valve coming out from between the webs (black bit ?) but the point to the centre of the wheel so 90* not 45*
Edited by Fastorq, 17 November 2018 - 09:25 PM.
Posted 19 November 2018 - 09:03 PM
As I’m trying to buy as many original / period parts for my mini build as possible I went out of my way to find a pair of good un-spaced second hand orig rear drum minifins
Unfortunately just discovered that they don’t fit the Mambas without bloody spacers ?
Posted 19 November 2018 - 11:15 PM
Posted 20 November 2018 - 05:55 AM
The offset on the Mamba is designed for the wider track of spacer drums in the rear and 7.5" discs at the front. They normally stick out of the body quite a bit too!
