Renewing Auto Mounts Any Tips?
4 replies to this topic
#1 designermatt
designermatt
  • 255 posts
Posted 18 November 2018 - 04:56 PM
Going to change the bottom engine subframe mounts on a 1992 rover auto  1275cc ,  Will I get away with disconnecting all engine mounts,stabilisers, exhaust , and whatever else and then lifting engine slightly and swapping them in.
Being an auto I think Its got a cable shifter , I dont want to damage or interfer with that as its working tremendously
#2 Boycie
Boycie
  • 1,978 posts
Posted 18 November 2018 - 08:12 PM
There's nothing particularly special about replacing the auto mounts, the method you propose will be fine and you can leave the selector cable well alone.  Good luck!
#3 designermatt
designermatt
  • 255 posts
Posted 18 November 2018 - 08:47 PM
Cheers, I know the manual ones can be fiddly getting the bolts out and getting a spanner on the nut but what fun would it be if it was too easy lol
#4 Boycie
Boycie
  • 1,978 posts
Posted 18 November 2018 - 09:04 PM
You're not wrong there!  Remember the auto subframe is wider than the manual, so in theory you have more working space... but then so is the gearbox so 'horses for courses'!
#5 nicklouse
  • 17,945 posts
Posted 18 November 2018 - 09:30 PM
a Fork can be useful.
