Primary Gears Stuck On
Best Answer nicklouse , 18 November 2018 - 05:25 PM
ok then it will just be a raised edge on the slot. quite common.
Go to the full post
4 replies to this topic
#1 JonnyAlpha
JonnyAlpha
  • 2,744 posts
  • Local Club: Exmoor Minis
Posted 18 November 2018 - 05:15 PM
Hi;
I am stripping down a 1275 and the Primary Gears, the ones that sit on the crankshaft behind the flywheel wont slide off past the C washer slot, something is catching.
Looking at the Bill Sollis 1380 Video he had the same problem and dressed it down with a needle file - I guess this is the solution.
Can't see what is catching though? Maybe I need new glasses :-)
#2 nicklouse
  • 17,945 posts
the edged of the slots will be raised. file it down.
#3 nicklouse
  • 17,945 posts
Posted 18 November 2018 - 05:16 PM
you have pulled the seal out of the housing?
#4 JonnyAlpha
JonnyAlpha
  • 2,744 posts
Posted 18 November 2018 - 05:21 PM
What seal? The Ali housings are all removed.
I'll get a pic maybe?
Edited by JonnyAlpha, 18 November 2018 - 05:21 PM.
#5 nicklouse
  • 17,945 posts
Posted 18 November 2018 - 05:25 PM   Best Answer
