Rough Running A+998
Posted 19 November 2018 - 05:37 PM
Posted 19 November 2018 - 05:50 PM
Have you checked tyre isn't rubbing on something? Is the brake disc and pads okay on that side ? Have you checked all the other wheel bearings to check if there okay? Might have to just go through everything on that front corner and check for play and wear etc...
Posted 19 November 2018 - 05:53 PM
Posted 19 November 2018 - 06:10 PM
Also some pattern bearings are trash
Posted 19 November 2018 - 06:47 PM
Posted 19 November 2018 - 07:04 PM
The new bearings were a tight fit. Notably, they were pre-assembled with the races fitted, so I had to fit them that way. Given that the noise is identical to before, I am thinking that it probably isn't the new bearings, but I could be wrong. If you think the sound is more bearing-like, than CV-like, perhaps I should replace the OS bearing before doing anything else? Thanks for your help.
Did you pack the new bearings with grease? otherwise it sounds like you've fitted them dry, The bearing and outer race are separate, and you install the outers into the hub , then you pack the new bearings/inners with grease and jobs a goodun
Posted 19 November 2018 - 08:28 PM
