Hello on this video i made a tutorial on how to remove the upper arm bearings on a classic mini. In the weekend i will edit the second part which is going to be how to convert hydroelastic to dry suspension keeping the original rear arms. stub axle hub bearings nut and washer was the easy part. the hard was to set the car in the back. hydro arms are better if you want a stiffer ride otherwise use dry arms for comfort
Edited by xydte, 25 November 2018 - 11:54 PM.
