Assembling Mpi Self Levelling Headlights.
13 replies to this topic
#1 Jordy869
Jordy869
  • 84 posts
Posted 27 November 2018 - 09:24 PM
I have recently bought new plastic bowls and trims for my headlights. However I’ve got the kits and everything but does anyone have any instructions or suggestions on how I know they are correctly put back together. When taken apart they sort of fell a part. ?
Pictures below to show what have got left and what it looks like. It still rattles a bit. Attached File  3EC8FB8E-F659-4A06-ABEB-0B3E40A600DA.jpeg   74.65K   7 downloadsAttached File  D978BF39-4D4B-403B-BE3D-E4E1646B087A.jpeg   76.34K   4 downloads
#2 Bat
Bat
  • 903 posts
Posted 27 November 2018 - 11:05 PM
Hi,
There should be 3 of those flat plates with the lump on them.
They hold the light into the metal frame.
MPIs don't use the spring.
Where's the leveling motor?
Cheers  :proud:
#3 Steve220
Steve220
  • 4,889 posts
  • Local Club: BMC
Posted 28 November 2018 - 12:05 PM
You've bought the wrong bowls.
#4 rich_959
rich_959
  • Just Joined
  • 568 posts
Posted 28 November 2018 - 12:20 PM
I was thinking the same. Need these, right?
http://www.minispare.../XBC105240.aspx
#5 Steve220
Steve220
  • 4,889 posts
  • Local Club: BMC
Posted 28 November 2018 - 12:21 PM
Correct.
#6 Jordy869
Jordy869
  • 84 posts
Posted 28 November 2018 - 01:32 PM
Steve 220/rich 959... you're wrong i have bought the correct mpi bowl that house the motor  :proud: the motor is located in the picture at the bottom by the floor.
#7 Jordy869
Jordy869
  • 84 posts
Posted 28 November 2018 - 01:35 PM
the bowl you have suggest is the very bowl i bought haha from minispares  :lol: i was adviced with the kits that has the spring, i am aware the spring isnt needed for the MPI however the 3 little plates ive got, i have two left. shall i have two left? or not
regards
#8 rich_959
rich_959
  • Just Joined
  • 568 posts
Posted 28 November 2018 - 02:24 PM
Apologies, couldn't see it in the pic! Can't help with assembly I'm afraid - mine are still in the bags, a long way from assembly!
Above, Bat says you should use three of those plates per light - so if you have only used one and have two left, it seems that could be your issue.
Minispares drawing doesn't seem to help
http://www.minispare...s.aspx?2~20~192
#9 Jordy869
Jordy869
  • 84 posts
Posted 28 November 2018 - 04:04 PM
no worries, no the drawing doesn't help whats so ever
#10 Steve220
Steve220
  • 4,889 posts
  • Local Club: BMC
Posted 28 November 2018 - 06:02 PM
Is the ring mounted correctly?
Edited by Steve220, 28 November 2018 - 06:07 PM.
#11 YJO
YJO
  • 49 posts
Posted 09 February 2019 - 07:21 PM
Hi , I am fairly sure one of my levelling motors has died , and the item is effected a sealed unit...has anyone tried opening one up with any degree of success ?
My duff one buzzes, I haven't yet tried swapping it with the one that works to make sure nothing is untoward and see how these work prior to being plumbed in, new ones are not the cheapest of parts.
#12 Steve220
Steve220
  • 4,889 posts
  • Local Club: BMC
Posted 10 February 2019 - 01:26 PM
Have you check your earthing first? I bought a new set only to find my originals worked and my earthing point was terrible.
#13 Curley
Curley
  • 469 posts
  • Local Club: Not MINI friendly
Posted 10 February 2019 - 06:18 PM
for completeness:
#14 YJO
YJO
  • 49 posts
Posted 11 February 2019 - 06:25 PM
Many ,thanks, good thought, I need to swap the two over first as the drivers side works fine as a check.
