Two Piece Speedo Cable
Posted 07 December 2018 - 02:36 PM
I intend to tow my Elf on an A frame behind my Motorhome, whilst On Tow, I’d rather not have the odometer recording distances.
As the ends of the speedo cable are not easily accessible, either behind the dash or on the bottom of the engine.
I’m hoping I can either get a two piece cable, or a short extension, to allow me to have an accessible, easily disconnectable joint under the bonnet.
Any info/advice would be really appreciated.
Posted 07 December 2018 - 02:50 PM
you don't want to be towing it with the driven wheels on the ground. good way to wear your gearbox out very fast,
you are making some bearings rotate very fast for long time periods when they were not designed for it.
Posted 07 December 2018 - 04:34 PM
Posted 08 December 2018 - 01:37 PM
Posted 08 December 2018 - 05:01 PM
I agree with Nick here.
There's a tiny bearing between the 1st and 3rd Motion Shafts that at normal highway speeds will be spinning well over it constant design rating and it'll be doing this with stone cold oil and an oil level that will be too high. I've got some photos I took of a gearbox that was damaged from doing just this.
I'd suggest using a dolly, and I would think legally, you would need to in any case.
Posted 08 December 2018 - 05:12 PM
Ivor it is not the length, I need to be able to disconnect the speedo easily & quickly. Currently is is too awkward to get to the back of the speedo or the take off on the gearbox. I’m hoping to be able to get hold of a cable with a disconnectable joint in the middle of it.
The 1100/1300 cable has a joint in the middle
Posted 08 December 2018 - 07:54 PM
Hi,
MPIs had a factory fitted 2 piece cable the join is on the bulkhead by where the fuel pipes come up.
Posted 08 December 2018 - 09:00 PM
Posted 31 January 2019 - 11:33 AM
Posted 31 January 2019 - 11:42 AM
again you don't want to be towing with the driven wheels on the road. do not expect the gearbox to like it one bit.
Posted 31 January 2019 - 04:30 PM
DUF definitely not listening to advice re potential gearbox trouble, more interested in keeping a few miles off the clock
Gearbox designed to be in neutral when at stand still and maybe very short distance towing.
Posted 31 January 2019 - 09:22 PM
What is the trouble with towing the car in neutral? The gearbox is still running in oil. In addition the trips using the A Frame will only be for around 75 miles & below 60 MPH, I’m not towing the car for hundreds of miles at high speed.
I cannot use a trailer as I do not have space to store one, as I have Duffy in the garage, my Motorhome on my garden & my Leon on the drive.
For those outside the UK a towing dolly can only be used for recovery, so could not be used behind a MoHo.
Posted 31 January 2019 - 11:36 PM
Gents
Cold Engine Oil doesn't lucubrate too well and to make matters worse, as the engine won't be running, the Oil Level will be higher than it normally is.
The 'Nose' bearing that I described earlier in this thread is tiny and in no way rated for continuous running, even in hot oil. This one is the one that spins when the Box in in Neutral.
This is what it does to the Mainshaft;-
Posted 01 February 2019 - 12:03 PM
Ultimately the gearbox is designed to do the majority of its mileage in fourth gear on long trips so both the 1st motion and 3rd motion shafts are turning together, and when not you get the result as shown by Moke Spider.
The first motion shaft is static when the engine is shut down.
Edited by Rorf, 01 February 2019 - 12:06 PM.
