Engine Whirling Noise
Posted 11 December 2018 - 10:40 PM
Any ideas?
Posted 11 December 2018 - 10:47 PM
Posted 11 December 2018 - 11:37 PM
Take the fan belt off and give it a quick run, that will eliminate that end if it's still making the noise.
Posted 12 December 2018 - 12:02 PM
alternator or fan catching cowling ?
Posted 12 December 2018 - 03:46 PM
Posted 12 December 2018 - 04:30 PM
Just sounds like normal fan noise to me.
But the fan does look a bit too far into the cowling.
Edited by panky, 12 December 2018 - 04:32 PM.
Posted 12 December 2018 - 06:03 PM
Use a long plastic screwdriver as a listening device. Place the tip onto the part Or area you want then place your ear on the other end
Definatly plastic side to your ear lol
Posted 12 December 2018 - 08:16 PM
Definatly plastic side to your ear lolUse a long plastic screwdriver as a listening device. Place the tip onto the part Or area you want then place your ear on the other end
That should read plastic handled screwdriver and yes plastic handle to the ear
Posted 14 December 2018 - 11:24 AM
Posted 14 December 2018 - 11:29 AM
Or the fan is touching .. when you spin it by hand (no belt) any noises?
Edited by gazza82, 14 December 2018 - 11:30 AM.
Posted 14 December 2018 - 11:57 AM
Posted 14 December 2018 - 12:37 PM
Check all the mounts for the alternator, had a strange noise a few years ago, turned out the bolt holding the adjuster bracket to the engine had broken and the bracket was moving around!
Posted 14 December 2018 - 12:55 PM
One thing to check is the lug on the engine front plate where the alternator bolts on. It has been known for that lug to fracture and cause a strange noise (had that). It can take a while to diagnose as it is not immediately obvious.
Posted 14 December 2018 - 05:13 PM
Sometimes a new fan belt or new-ish one that's been refitted on a different pulley or in the reverse direction to how it previously ran can make a sound like that. This usually settles down after about 100 miles.
